Problem running stepper in reverse from analog input
Been trying to see where Im going wrong with this for a while now and cant seem to get the motor to do what I want . Its will most likely be due to my inexperience with the programming and despite trying to push through I cannot get the functions I am trying for.
Problem:
I have an analogue input (pot) and want to make a stepper spin clockwise if the value is >500 and counter-clockwise if it is <500.
Below are a couple of attempts within my code as well as the current iteration. Spinning cw is fine but the best I seem to manage is to stall the motor when trying reverse. Ideally I would like proportional control but getting this working using only my own skills and information gleaned from the interweb isnt working.
Hope someone can help.
#include <AccelStepper.h>
AccelStepper stepper;
const int Xdeadzone = 3, Ydeadzone = 3; // slack for pot values
#define ANALOG_IN A0
  stepper.setMaxSpeed(1000);
  stepper2.setMaxSpeed(1000);
 // stepper.moveTo(ANALOG_IN);
 // stepper.setSpeed(700);
  //stepper2.setSpeed(700);
  //stepper.moveTo(1024);
 int X = analogRead(ANALOG_IN);
 Serial.println(X);
 //int right =  (X, 502, 907,  0, 1000);
 //int left =  map(X, 0, 496, 0, 255);
 //int motorSpeed2 = map(sensorReading, 0, 320, 0, 100);
 if (X >= (499 + Xdeadzone))
    stepper.runSpeedToPosition();
  else if (X < (499 - Xdeadzone))
    stepper.moveTo((-stepper.currentPosition()));
if (X = (499 +- Xdeadzone));
  stepper.setCurrentPosition(0);
if (X >= (499 + Xdeadzone));//Right
  stepper.moveTo(-ANALOG_IN);
void cw()
  if (stepper.distanceToGo() == X) {
    stepper.moveTo(-stepper.currentPosition());
  stepper.run();
I'm not familiar with AccelStepper but ...
Can you write two short sketches without any pot input that make the motor run in fwd and in reverse?
Then can you modify them to allow the speed (if that's what you are interested in) to be controlled by the pot?
If so all you need to do is combine them.
You eat an elephant one bite at a time.
...R
