Hardware config:
- Wiznet W5100 ethernet shield stacked on top of an Arduino Uno R3.
- Arduino Uno connected to the PC via USB cable to upload code.
- RJ45 cable connected from the Internet router to the ethernet shield.
Upon running the basic web server example from File > Examples > Ethernet > WebServer
The console prints a confirmation message that the server is started at chosen IP address, 192.168.1.177. However, when I call the IP address using a web browser the loading process takes ~30 seconds before responding that the site is not reachable. The strange thing here is that I'm able to ping the IP successfully. Also, when I ping the IP I see that the Tx, Rx, LED of the ethernet shields are blinking which means that it successfully connected the network and receiving the ping request & replying to it.
Any suggestion as to why the web server is not responding despite the IP being reachable? I have used the same setup before two months & it used to working fine. Not sure what have changed. [Below is a picture for the experiment]
What browser are you using? Chrome has a pesky habit of asking for a favorite icon after the initial request. Otherwise maybe something in your web page has been changed. Are you trying to upload images from an SD card?
Thanks @zoomkat
Chrome and also tried safari from my Mac machine. Also, the page is not accessible even if I try to access from browser on my smartphone.
No. I'm just starting with the basic Web Server Example. The code can be opened from the IDE window by selecting (File > Examples > Ethernet > WebServer).
You might post the code you are using in code tags </> so others with an ethernet card might run it and see if they have the same issues, or see issues with the code as you have implemented it.
Sure. Below is the code, which is the basic example available from the IDE. Again, the strange thing here is that I can ping the Arduino board but still the HTML page cannot be accessed when I call the same IP from the browser.
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
modified 02 Sept 2015
by Arturo Guadalupi
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
