Problem saving an array
Hello everybody,
I am doing a program in arduino and I have a question / problem:
My program controls a robotic arm with 4 dynamixel motors using an ArbotiX-M. I move manually the arm and the program saves the positions of the movements of the motors in an array. Afterwards, the program plays the sequence and the arm moves repeating the sequence that has been saved.
My problem is that the maximum number of positions that I can save are 400, (I mean, 400 positions for each engine, 1600 positions),aand if I put to store more positions the program goes crazy.
So, I would like to know if I am exceeding the limit of any memory, because when compiling what it says is:
"The sketch uses 8,656 bytes (13%) of the program's storage space, the maximum is 65,536 bytes.
Global variables use 806 bytes (19%) of dynamic memory, leaving 3,290 bytes for local variables. The maximum is 4,096 bytes. "
If so, is there a solution ???
many thanks,
Urko.
Post.Your. Code.
In code tags
    Program to control Dynamixel of robotic arm by urko_18
#include <ax12.h> //Include ArbotiX DYNAMIXEL library
int kop = 4; //Cuantity of dynamixel
int SERVO_ID[] = {1, 2, 3, 4}; // ID numbers
int regData1, regData2, regData3, regData4;
int turns = 0;
int turns2 = 0;
int turns3 = 0;
int turns4 = 0;
int l, i, repetitions;
double Speed;
/*****(r = 1; m = 420) (r = 2; m = 210) (r = 3; m = 140) (r = 4; m = 105)*****/ // maximun "m" for differents "r"
int m = 400; //columns
int r = 1; //rows
 dxlInit(1000000); //start dynamixel library at 1mbps to communicate with the servos
 Serial.begin(9600); //start serial at 9600 for reporting data.
 Relax(SERVO_ID[0]);
 Relax(SERVO_ID[1]);
 Relax(SERVO_ID[2]);
 Relax(SERVO_ID[3]);
 Serial.print("ID: ");
 Serial.println(SERVO_ID[0]);
 Serial.print ("ID: ");
 Serial.println(SERVO_ID[1]);
 Serial.println(SERVO_ID[2]);
 Serial.println(SERVO_ID[3]);
 int positionn1[r][m]; //Matrix of movements
 int positionn2[r][m];
 int positionn3[r][m];
 int positionn4[r][m];
 a:
 Serial.println("How fast do you want to repeat the sequence?");
 Serial.println(" 1 = Slow     2  = Normal     3 = Fast");
 while (Serial.available() == 0) {}
 Speed = Serial.parseInt();
 while (Speed >=4){
 Serial.println("You have entered a wrong value");
 goto a;
 while (Speed ==1){
 Speed=1000;
 while (Speed ==2){
 Speed=700;
 while (Speed ==3){
 Speed=400;
 Serial.print("Speed = ");
 Serial.print(Speed, 0);
 Serial.println(" microseconds");
 delay(3000);
 Serial.println("How many times do you want to repeat the sequence?");
 repetitions = Serial.parseInt();
 Serial.print("repetitions = ");
 Serial.println(repetitions);
 delay(3000);
 for (l = 0; l < r; l++) // structure to create rows
   Serial.print("Positions vector ");
   Serial.print(l + 1);
   Serial.print(": [");
   for (i = 0; i < m; i++) // structure to create columns
     regData1 = dxlGetPosition(SERVO_ID[0]); //read and save the actual position
     regData2 = dxlGetPosition(SERVO_ID[1]);
     regData3 = dxlGetPosition(SERVO_ID[2]);
     regData4 = dxlGetPosition(SERVO_ID[3]);
     positionn1[l] = regData1; //Creation movements vector
     positionn2[l] = regData2;
     positionn3[l] = regData3;
     positionn4[l] = regData4;
     delay(20);
     Serial.print(positionn1[l]); //Display the vector
     Serial.print(", ");
     Serial.print(positionn2[l]);
     Serial.print(", ");
     Serial.print(positionn3[l]);
     Serial.print(", ");
     Serial.print(positionn4[l]);
     Serial.print("; ");
   Serial.print("]\n");
   if (l < (r - 1)) {
     Serial.println("Next movement");
   delay(2000);
 delay(5000);
 Serial.println("The servos will move to the initial position.");
 /***The servos will move according to registered movements***/
 for (int a = 0; a < repetitions; a++) //Repetition of the process (a = number of sequences)
   Serial.print("SEQUENCE ");
   Serial.println(a + 1);
   int before_position_1, before_position_2, before_position_3, before_position_4;
   int position1 = positionn1[0][0];
   int position2 = positionn2[0][0];
   int position3 = positionn3[0][0];
   int position4 = positionn4[0][0];
     //First, the servos will move to initial position, in order to do the registered movements
     int pos1_1 = dxlGetPosition(SERVO_ID[0]); //Actual servo position
     int pos1_2 = dxlGetPosition(SERVO_ID[1]);
     int pos1_3 = dxlGetPosition(SERVO_ID[2]);
     int pos1_4 = dxlGetPosition(SERVO_ID[3]);
     int pos2_1 = positionn1[l][0]; //Initial position of the movement (objective)
     int pos2_2 = positionn2[l][0];
     int pos2_3 = positionn3[l][0];
     int pos2_4 = positionn4[l][0];
     posiziora_joan(pos1_1, pos1_2, pos1_3, pos1_4, pos2_1, pos2_2, pos2_3, pos2_4); //Function that moves the robot to the initial position
     if (l == 0) {
       Serial.println("Now the servos will do the registered movements.");
     delay(2000);
     //Now, they will move through the registered positions
     int  initial1 = positionn1[l][0];
     int  initial2 = positionn2[l][0];
     int  initial3 = positionn3[l][0];
     int  initial4 = positionn4[l][0];
       //ID1
       if (positionn1[l] < initial1)
         while (positionn1[l] < initial1)
           before_position_1 = initial1;
           dxlSetGoalPosition(SERVO_ID[0], initial1);
           initial1--;
           delayMicroseconds(Speed);
           if (initial1 != before_position_1)
             if (initial1 == position1 + MX_MAX_POSITION_VALUE)
               position1 = initial1;
               turns++;
               Serial.print("Turns engine 1: ");
               Serial.println(turns);
             else if (initial1 == position1 - MX_MAX_POSITION_VALUE)
               turns--;
       else if (positionn1[l] > initial1)
         while (positionn1[l] > initial1)
           initial1++;
               turns++;
               turns--;
####### THE SAME WITH THE OTHER MOTORS (ID2 ID3 ID4)#######
     Serial.println(" ");
     delay(1000); //Pause between movements
   delay(300); //Pause between sequences
 delay(7000);
 /****REST POSITION****/
 Serial.println("The robot will move to the resting position.");
 int pos1_1 = dxlGetPosition(SERVO_ID[0]); //actual robot position
 int pos2_1 = 3820; //rest position of the robot (the positions of the 4 dynamixel)
 int pos2_2 = 400;
 int pos2_3 = 230;
 int pos2_4 = 2395;
 posiziora_joan(pos1_1, pos1_2, pos1_3, pos1_4, pos2_1, pos2_2, pos2_3, pos2_4);//function
 Relax(SERVO_ID[0]);
 Relax(SERVO_ID[1]);
 Relax(SERVO_ID[2]);
 Relax(SERVO_ID[3]);
 Serial.println("END!");
It doesn't make sense (to me) to have these a local automatic variables, but if you do the sums, you'll see where your RAM is going.
And then I saw this
 a:
Thanks for answering!
So, what is it that you would do with the local automatic variables ?
Regarding the issue of
to:
I do not understand what you want to tell me, it's a goto, does something happen with that?
urko_18:
Shrink them, and make them global.
to:
It's a label, and labels usually have an associated goto.
Why are you using goto?
Could you explain or give me an example of how they can be reduced or converted to global?
Regarding the goto, I do not know, it was the first idea that occurred to me so that the program would return to the site of the code that I want. Can you say to mee any other way more simply or better?
Thank you!
Urko.
You should really use some ‘if else’ statements for that first part of the loop…
Something like
 if(Speed <= 0 || Speed >= 4)
  return;
 if (Speed == 1)
  Speed=1000;
 else if (Speed ==2)
  Speed = 700;
 else if (Speed == 3)
  Speed=400;
P.s don’t do goto
Thank you!
I have already changed it and it works perfectly !!
just out of curiosity, why is it better not to use goto ??
Urko.
Because using goto makes you look clueless.
