Hello all, i am currently experiencing an issue trying to save information to an SD card i have attached with a shield. The outcome would be to capture how many times a servo motor runs at a certain part within the main loop. i keep retrieving a fail at the SD Initialization on the serial monitor as if it the FILE_WRITE function fails to even work! Any help would be appreciated. I inserted a small block if the code below containing the trouble areas and the full version of the code in the attachment.
Thanks alot!!!
#include <SPI.h>
#include <SD.h>
String readString;
int Distance_to_Preheat;
int Preheat_Dwell;
int Distance_to_Dip;
int Dwell_Time;
int Distance_to_Raise;
int Spin_Time;
int Upper_Limit = A0;
int Lower_Limit = A1;
int E_Stop = 2;
int Return = 3;
int Start = 5;
int Spindle_EN = 6;
int Step_Direction = 8;
int Step_Speed = 10;
int Debug = 3000;
int Step_Counter = 0;
int E_Stop_State = 0;
int Return_State = 0;
int Start_State = 0;
int Up = 0;
int Down = 0;
int Preheat = 0;
int Dip = 0;
int Raise = 0;
int Spin = 0;
int Home = 0;
while (!Serial) {
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
} //End Setup
if(Serial.available() > 0) {
while (Serial.available()) {
delay(10);
char commandInChar = Serial.read();
readString += commandInChar;
///Start of Spin Motor and SD Read/Write
if(Spin == 1){
digitalWrite(Spindle_EN, HIGH);
delay(1);
Step_Counter = Step_Counter + 1;
if(Step_Counter >= Spin_Time || digitalRead(E_Stop) == LOW || Return_State == HIGH ){
digitalWrite(Spindle_EN, LOW);
Step_Counter = 0;
Spin = 0;
Home = 1;
if(digitalRead(E_Stop) == LOW || Return_State == HIGH ){
Spin = 0;
Home = 0;
Serial.print("i H8 LYFE");
DataLogs();
Serial.print("i lUV LYFE");
///End of Spin Motor and SD Read/Write
} //End Void Loop
void DataLogs() {
File myFile = SD.open("TEST.TXT", FILE_WRITE);
if (myFile) {
myFile.println("Spindle Activity Enabled/Detected");
myFile.close();
else {
Serial.println("error opening TEST.TXT");
myFile = SD.open("TEST.TXT");
if (myFile) {
Serial.println("TEST.TXT: content");
while (myFile.available()) {
Serial.write(myFile.read());
myFile.close();
else {
}//End DataLogs*/
AGR_v2.1.ino (7.81 KB)
