problem send email
hello I try to send an email from arduino ethernet through an account smt2go and telnet but I do not know where is the problem because my receiver does not receive anything in spite of write the commands of telnet are well like you can see on the image attachment , the weirdest is the report in my smtp2go account records the shipping.
thanks.
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp.h>
#include <util.h>
#include <SPI.h>
byte mac[] = {0x90, 0xA2, 0xDA, 0x0D, 0x5C, 0x18};//mac of my arduino ethernet
byte smtp[] = { 207,58,147,66 }; //nslookup to smtpcorp.com
EthernetServer server(80);
EthernetClient client;
  Serial.println("wating");
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    for(;;);
  Serial.print("My IP address: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    Serial.print(Ethernet.localIP()[thisByte], DEC);
    Serial.print(".");
  delay(2000);
  Serial.println("connecting...");
  if (client.connect(smtp,8025)) //2525/25/8025/587/465/8465 // I tried with all ports
    client.println("ehlo");
    client.println("auth login");
    client.println("xxxxxxxxxxxx");  //mail account with smtp2go base64
    client.println("xxxxxxxxxxxx"); //password with smtp2go base64
    client.println("mail from: ekarduino001@gmail.com");
    client.println("rcpt to: xxxxxxxxxxxx");
    client.println("data");
    client.println("To: USER");
    client.println("From: ekarduino001");
    client.println("Subject: MENSAJE DE PRUEBA");
    client.println();
    client.println("ESTE ES UN MENSAJE DE PRUEBA DESDE ARDUINO");
    client.println(".");
    client.println("quit");
  else {
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // as long as there are bytes in the serial queue,
  // read them and send them out the socket if it's open:
  while (Serial.available() > 0) {
    char inChar = Serial.read();
    if (client.connected()) {
      client.print(inChar);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    // do nothing:
    while(true);
Hard to tell with your code above. Port 2525 works with the ip you used. I didn't send anything, but I made a connection. I used PuTTY in raw mode.
220 smtpcorp.com ESMTP Exim 4.72 Sun, 01 Sep 2013 21:22:45 +0000
Try my email code. Even if it doesn't work, it displays the email server response, so you should know why it failed.
http://playground.arduino.cc/Code/Email
