Problem sending a char[] to the LCD [SOLVED]
Hi all,
I am trying to switch from Strings to char
The Library I am writing returns a char*
Serial.println(menu.getChar());
outputs OK on the serial monitor
lcd.print(menu.getchar());
generates a: ‘class Menu’ has no member named ‘fgetc’ on compile time.
Can someone shed some light on this for me?
(I added #include <stdio.h> in all the files: .h .cpp. .ino) but no cigar.
EDIT : I tried
lcd.print(&menu.getchar());
Same error.
Jacques
In the one you said worked you spelled it differently. Are you sure you're calling the same function? C++ is case sensitive. getChar != getchar
Post your code and links to the menu library you're using. It's kinda hard to help much more without that.
Hey Delta_G
You've got it pinned.
When I do this kind of booo booo, I recieve a "Not defined in this scope" warning.
Guess I'll have to get a good night sleep before going on with this Library.
Thanks a lot to have taken the time to fool proof my code.
Jacques
