Hi Everyone,
We are now able to send multiple sensor values using ArduinoBle library.
as suggested at the following link:
Our next issue is that we are traying to connect multiple sensors to Arduino nano 33 ble using TCA9548A multiplexer and collecting the data using I2c Protocol.
We would like to send the data collected from multiple sensors using the multiplexer using ble.
However, when we try to do so the bluepy library (python code) is not able to connect to the arduino using ble.
it gives the following error (on raspbery pi zero, using bluepy python library):
"buepy.btle.BTLEDisconnectError: Failed to coonect to peripheral"
We are using the following code
// IMPORTING LIBRARIES
#include "Arduino.h"
/* For the bluetooth funcionality */
#include <ArduinoBLE.h>
#include <Arduino_LSM9DS1.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
#define TCAADDR 0x70
Adafruit_MPU6050 mpu;
// Defining Characteristics
#define BLE_UUID_SENSOR_DATA_SERVICE "2BEEF31A-B10D-271C-C9EA-35D865C1F48A"
#define BLE_UUID_MULTI_SENSOR_DATA "4664E7A1-5A13-BFFF-4636-7D0A4B16496C"
// Creating a union to store data
#define NUMBER_OF_SENSORS 6
const int ledPin = LED_BUILTIN; // set ledPin to on-board LED
union multi_sensor_data
struct __attribute__( ( packed ) )
float values[NUMBER_OF_SENSORS];
uint8_t bytes[ NUMBER_OF_SENSORS * sizeof( float ) ];
union multi_sensor_data multiSensorData;
// Given sensor i, select and write to it
void tcaselect(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
//Service for publish Accelerometer value...
BLEService sensorDataService( BLE_UUID_SENSOR_DATA_SERVICE );
BLECharacteristic
multiSensorDataCharacteristic( BLE_UUID_MULTI_SENSOR_DATA, BLERead |
BLENotify, sizeof multiSensorData.bytes );
float acc_x, acc_y, acc_z;
while (!Serial);
pinMode(ledPin, OUTPUT); // use the LED as an output
// BLE initialization
if (!BLE.begin()) {Serial.println("starting BLE failed!");
while (1);
// IMU initialization
if (!IMU.begin())
{Serial.println("Failed to initialize IMU!");
while (1);
BLE.setDeviceName("IMU");
// set the local name peripheral advertises
BLE.setLocalName("IMU");
BLE.setAdvertisedService(sensorDataService);
// BLE add characteristics
sensorDataService.addCharacteristic( multiSensorDataCharacteristic );
// add service
BLE.addService( sensorDataService );
// set the initial value for the characeristic:
multiSensorDataCharacteristic.writeValue( multiSensorData.bytes, sizeof multiSensorData.bytes );
BLE.setConnectable(true);
BLE.advertise();
Serial.println("Bluetooth Device Active, Waiting for Connections...");
Serial.println(" AX \t AY \t AZ");
BLEDevice central = BLE.central();
if(central) {
Serial.print("Connected to Central: ");
Serial.println(central.address());
while(central.connected()) {
IMU.readAcceleration(acc_x, acc_y, acc_z);
multiSensorData.values[0] = acc_x;
multiSensorData.values[1] = acc_y;
multiSensorData.values[2] = acc_z;
// We can easily capture and send acc_x,acc_y and acc_z in our data packet using ble
// If we exclude the following part of the code, then we can collect the data in python using our previous code.
sensors_event_t a, g, temp;
tcaselect(2);
mpu.getEvent(&a, &g, &temp);
multiSensorData.values[3] = a.acceleration.x; //a.acceleration.x;
multiSensorData.values[4] = a.acceleration.y; //a.acceleration.y;
multiSensorData.values[5] = a.acceleration.z; //a.acceleration.z;
// if we add a.acceleration.x,a.acceleration.y,a.acceleration.z then the python code gives us
// the above error
Serial.print(acc_x);
Serial.print(acc_y);
Serial.print(acc_z);
Serial.print("Disconnected from Central: ");
Serial.println(BLE.address());
Any suggestions are welcome.
I am a beginner in embedded software design, and it would help me a lot if I can learn to get over this issue.
Thank you in advance
