Problem sending data from Java Server to Arduino MKR1000 via WIFI.
I’m working on a project that lets me stream audio data from a Java server to an Arduino MKR1000 using sockets. I’m using the WiFi101 library for the client side (MKR1000) and java.io sockets for the server side (PC).
As a test, I tried sending a string instead of the audio data. The Arduino connects to the remote server no problem. However, when the client attempts to read the data written to the socket, the MKR1000 just prints “⸮” many many times. I’m not sure why this is happening and I am unable to find a similar problem online. The the baud rate is set to 9600 in the code and the serial monitor. Any help would be much appreciated.
Serial Monitor output:
Connecting to ssid: KIW
Connected to Wifi
SSID: KIW
IP Address: 192.168.43.149
Signal Strength (RSSI): -49 dBm
Connecting to server...
Connection Success!
Java Server Code:
import java.io.*;
import java.net.*;
   * Test server for Arduino WiFiClientTest.ino
public class Server {
 //Globals
 private static String message;
 private static int port;
 private static ServerSocket ss;
 private static Socket s;
 private OutputStreamWriter osw;
 private static BufferedInputStream br;
 private static BufferedWriter bw;
 public static void main(String[] args) throws IOException {
 port = 5005;
 System.out.println("Starting Server on localhost port " + port + "...");
 socketSendString("Hello World \n");
 public static void socketSendString(String msg) throws IOException {
 try{
 ServerSocket ss = new ServerSocket(port);
 Socket s = ss.accept();
 OutputStreamWriter osw = new OutputStreamWriter(s.getOutputStream());
 osw.write(msg, 0, msg.length());
 osw.close();
 s.close();
 ss.close();
 } catch(IOException e) {
 e.printStackTrace();
Arduino Client Code:
#include <SPI.h>
#include <WiFi101.h>
char ssid[] = "ssid";          //  your network SSID (name)
char pass[] = "pass";   // your network password
int status = WL_IDLE_STATUS;
char servername[]="serverIP";  // remote server we will connect to
int port = 5005;
WiFiClient client;
  //initialise serial and wait for port to open
  while(!Serial) {
    ; // wait for serial port to connect
  if(WiFi.status() == WL_NO_SHIELD) {
    Serial.println("Wifi shield not present");
    //Do nothing forever
    while(true);
  // Connect to the Wifi network
  while(status != WL_CONNECTED) {
    Serial.print("Connecting to ssid: ");
    Serial.println(ssid);
    //Connect to WPA/WPA2 Network
    status = WiFi.begin(ssid, pass);
    //Wait 20 seconds
    delay(20000);
  Serial.println("Connected to Wifi");
  wifiStatus();
  Serial.println("Connecting to server...");
  //If we get a connection, tell us
  if(client.connect(servername, port)) {
    Serial.println("Connection Success!");
    client.println();
  //If there are incoming bytes from server, read and print them
  while(!client.available()) {
    char c = client.read();
    Serial.write(c);
  //if the server disconnects stop the client
  if(!client.connected()) {
    Serial.print("Disconnecting from the server...");
    client.stop();
    //Then do nothing forever
    while(true);
void wifiStatus() {
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  //Print Arduinos ip address
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  //Print signal strenght to WIFI
  long rssi = WiFi.RSSI();
  Serial.print("Signal Strength (RSSI): ");
  Serial.print(rssi);
  Serial.println(" dBm");
Thanks in advance.
    Serial.write(c);
You're reading characters from the network as long as there arent' any available. This will always result in a -1 value returned and casted to a character it's 0xff, the character you see in the serial monitor.
