Problem sending data to cloud..
Hi.. I'm trying to send data of 3 variables to ubidots. The data is not showing up on Ubidots.. Here is my code please check it where is the actual problem.
#define ssid "xxxxxxxxxxxxx"                        // Put here your SSID
#define password "xxxxxxxxxx"                       // Put here your PASSWORD
#define id1 "xxxxxxxxxxxxxxxxxxxxxxxx"              // Put here your Ubidots variable ID1
#define id2 "xxxxxxxxxxxxxxxxxxxxxxxx"              // Put here your Ubidots variable ID2
#define id3 "xxxxxxxxxxxxxxxxxxxxxxxx"              // Put here your Ubidots variable ID3
#define token "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"  // Put here your Ubidots TOKEN
  Serial.println("\nModule Settings WiFi ESP8266");
  sendCmd("AT+RESTORE", "R", 1000);                                                    // cmd AT+RESTORE: Restores the Factory Default Settings
  sendCmd("AT+RST", "WiFi Module Ready!", 1000);                                       // cmd AT+RST: Restarts the Module
  sendCmd("AT+CWMODE=3", "Ap+Station Mode", 1000);                                     // cmd AT+CWMODE=3: Sets the Wi-Fi Ap + Station Mode
  sendCmd("AT+CWJAP=\""ssid"\",\""password"\"", "Successful WiFi Connection!", 5000);  // cmd AT+CWJAP: Connects to an AP
  sendCmd("AT+CIPMUX=1", "Enable Multiple Connections!", 500);                         // cmd AT+CIPMUX=1: Enable Multiple Connections
  int dato1 = analogRead(0);
  //  float dato1 = analogRead(0);
  int dato2 = analogRead(1);
  //  float dato2 = analogRead(1);
  int dato3 = analogRead(2);
  //  float dato3 = analogRead(2);
  send_D(dato1, dato2, dato3, 3);  // The last parameter "3", is for choose the number of variables to send to Ubidots: (1-3)
// Function to send data to Ubidots *************************************************************************************************************
void send_D(int d1, int d2, int d3, int n_var) {  // Send int data
//  void send_D(float d1, float d2, float d3, int n_var) {  // Send float data
  int string_length = 0, long_json = 0, SEND = 0;
  String Inicio, Final, variable[10];
  // JSON
  Inicio = "[";
  variable[1] = "{\"variable\": \"" + String(id1) + "\",\"value\":" + String(d1);
  variable[2] = "}, {\"variable\": \"" + String(id2) + "\",\"value\":" + String(d2);
  variable[3] = "}, {\"variable\": \"" + String(id3) + "\",\"value\":" + String(d3);
  Final = "}]";
  for(int i = 1; i <= n_var; i++) {
    string_length += variable[i].length();
  long_json = string_length + Inicio.length() + Final.length();
  //  Serial.println(long_json);
  String send1, send2, send3, send4, send5;
  int long_post = 0;
  // POST
  send1 = "POST /api/v1.6/collections/values/ HTTP/1.1\r\n";
  long_post = send1.length();
  send2 = "Content-Type: application/json\r\nContent-Length: ";
  long_post += send2.length();
  send3 = String(long_json) + "\r\nX-Auth-Token: ";
  long_post += send3.length();
  send4 = String(token);
  long_post += send4.length();
  send5 = "Host: things.ubidots.com\r\n";
  long_post += send5.length();
  SEND = long_json + long_post + 5;
  //  Serial.println(SEND);
  Serial.println(F("\n**********************************************************************************************************************************************************************\n"));
  Flush();
  Serial.println(F("AT+CIPSTART=4,\"TCP\",\"things.ubidots.com\",80"));  // cmd AT+CIPSTART: Establishes TCP Connection
  delay(5000);
  Flush();
  Serial.println("AT+CIPSEND=4," + String(SEND));                     // cmd AT+CIPSEND: Sends Data
  Serial.print(send1);
  Serial.print(send2);
  Serial.print(send3);
  Serial.println(send4);
  Serial.println(send5);
  Serial.print(Inicio);
    Serial.print(variable[i]);
  Serial.println(Final);
// Function for AT commands *********************************************************************************************************************
void sendCmd(char* cmd, char* ans, int t) {
  boolean Er = true;
  Flush();
  Serial.println(cmd);
  delay(t);
  while(Serial.available()) {
    if(Serial.find("OK")) {
      if(ans == "R") {
        Serial.print(".");
        Serial.print(".");
        Serial.println(".\n");
      else {
        Serial.println(ans);
      Er = false;
  if(Er == true) {
    Serial.println("Error");
    if(ans == "Successful WiFi Connection!") {
      if(Er == true) {
        Serial.println("WiFi Disconnected!");
// Function to clean Buffer Serial **************************************************************************************************************
void Flush() {
  byte w = 0;
  for (int i = 0; i < 10; i++) {
    while (Serial.available() > 0) {
      char k = Serial.read();
      w++;
      delay(1);
    delay(1);
I'm using Arduino UNO and ESP8266-01.
Please check the screenshot below to get the better understanding and the output.
Here is the screenshot of my serial monitor too..
Array indices start at 0, not 1.
Reading the server response just might provide a clue by 4.
PaulS:
You mean here i add 0,1,2 instead of 1,2,3??
Inicio = "[";
 Final = "}]";
Yes. Don't forget to do it where you get the length of the Strings, too.
You should also quit pissing away resources on Strings. Use sprintf() and strings (NULL terminated arrays of chars).
How i can print the server response in my serial monitor to check whether it is accepting my JSON format or not? What changes are required in my code please guide me
Serial to Monitor and Serial to ESP?
Juraj:
Serial to ESP
