PROBLEM SENDING SENSOR DATA TO THE THINGS NETWORK
Hi, i am trying to send sensor data from the HC-SR04 with an Arduino mega and a lora shield to The Things Network. I can send text messages like Hello World but it doesn't work with the sensor data. I am also not too expirienced with programming so would be great if someone could help me.
This is my code:
#include <HCSR04.h>
#include <arduino_lmic_user_configuration.h>
#include <arduino_lmic_hal_configuration.h>
#include <lmic.h>
#include <arduino_lmic.h>
#include <arduino_lmic_hal_boards.h>
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
//init HC SR04
int triggerPin = 2;
int echoPin = 3;
UltraSonicDistanceSensor distanceSensor(triggerPin, echoPin);
#ifdef COMPILE_REGRESSION_TEST
define FILLMEIN 0
#else
warning "You must replace the values marked FILLMEIN with real values from the TTN control panel!"
define FILLMEIN (#dont edit this, edit the lines that use FILLMEIN)
#endif
// This EUI must be in little-endian format, so least-significant-byte
// first. When copying an EUI from ttnctl output, this means to reverse
// the bytes. For TTN issued EUIs the last bytes should be 0xD5, 0xB3,
// 0x70.
static const u1_t PROGMEM APPEUI[8]={xx};
void os_getArtEui (u1_t* buf) { memcpy_P(buf, APPEUI, 8);}
// This should also be in little endian format, see above.
static const u1_t PROGMEM DEVEUI[8]={xx};
void os_getDevEui (u1_t* buf) { memcpy_P(buf, DEVEUI, 8);}
// This key should be in big endian format (or, since it is not really a
// number but a block of memory, endianness does not really apply). In
// practice, a key taken from ttnctl can be copied as-is.
static const u1_t PROGMEM APPKEY[16] = {xx};
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
static osjob_t sendjob;
// Schedule TX every this many seconds (might become longer due to duty
// cycle limitations).
const unsigned TX_INTERVAL = 30;
// Pin mapping
const lmic_pinmap lmic_pins = {
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 9,
.dio = {2, 6, 7 },
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F("EV_SCAN_TIMEOUT"));
case EV_BEACON_FOUND:
Serial.println(F("EV_BEACON_FOUND"));
case EV_BEACON_MISSED:
Serial.println(F("EV_BEACON_MISSED"));
case EV_BEACON_TRACKED:
Serial.println(F("EV_BEACON_TRACKED"));
case EV_JOINING:
Serial.println(F("EV_JOINING"));
case EV_JOINED:
Serial.println(F("EV_JOINED"));
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
LMIC_getSessionKeys(&netid, &devaddr, nwkKey, artKey);
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print("artKey: ");
for (int i=0; i<sizeof(artKey); ++i) {
Serial.print(artKey, HEX);
Serial.println("");
Serial.print("nwkKey: ");
for (int i=0; i<sizeof(nwkKey); ++i) {
Serial.print(nwkKey, HEX);
Serial.println("");
// Disable link check validation (automatically enabled
// during join, but because slow data rates change max TX
// size, we don't use it in this example.
LMIC_setLinkCheckMode(0);
|| This event is defined but not used in the code. No
|| point in wasting codespace on it.
|| case EV_RFU1:
|| Serial.println(F("EV_RFU1"));
|| break;
case EV_JOIN_FAILED:
Serial.println(F("EV_JOIN_FAILED"));
case EV_REJOIN_FAILED:
Serial.println(F("EV_REJOIN_FAILED"));
case EV_TXCOMPLETE:
Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
if (LMIC.txrxFlags & TXRX_ACK)
Serial.println(F("Received ack"));
if (LMIC.dataLen) {
Serial.print(F("Received "));
Serial.print(LMIC.dataLen);
Serial.println(F(" bytes of payload"));
// Schedule next transmission
os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
case EV_LOST_TSYNC:
Serial.println(F("EV_LOST_TSYNC"));
case EV_RESET:
Serial.println(F("EV_RESET"));
case EV_RXCOMPLETE:
// data received in ping slot
Serial.println(F("EV_RXCOMPLETE"));
case EV_LINK_DEAD:
Serial.println(F("EV_LINK_DEAD"));
case EV_LINK_ALIVE:
Serial.println(F("EV_LINK_ALIVE"));
|| case EV_SCAN_FOUND:
|| Serial.println(F("EV_SCAN_FOUND"));
|| break;
case EV_TXSTART:
Serial.println(F("EV_TXSTART"));
default:
Serial.print(F("Unknown event: "));
Serial.println((unsigned) ev);
void do_send(osjob_t
j){
// Check if there is not a current TX/RX job running
if (LMIC.opmode & OP_TXRXPEND) {
Serial.println(F("OP_TXRXPEND, not sending"));
//read distance from HC-SR04
uint32_t mydistance = distanceSensor.measureDistanceCm() * 100;
Serial.println("Distance: " + String(mydistance));
byte payload[2];
payload[0] = highByte(mydistance);
payload[1] = lowByte(mydistance);
// Prepare upstream data transmission at the next possible time.
LMIC_setTxData2(1, (uint8_t*)payload, sizeof(payload), 0);
Serial.println(F("Packet queued"));
// Next TX is scheduled after TX_COMPLETE event.
delay(5000);
while (! Serial);
Serial.println(F("Starting"));
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
digitalWrite(VCC_ENABLE, HIGH);
#endif
// LMIC init
os_init();
// Reset the MAC state. Session and pending data transfers will be discarded.
LMIC_reset();
// Start job (sending automatically starts OTAA too)
do_send(&sendjob);
os_runloop_once();
Thank you :slight_smile:
