Hi guys! I'm newbie here so please bare with me. And sorry for my bad english.
Go back to the subject, I'm having a project where in I need to send 3 different sms messages with respect to 3 different inputs(HIGH or LOW) of my 2 sensors and 1 switch on my atmega328 digital i/o pins. I connected rx of my sim900d to tx of atmega328 and tx of the sim900d to the rx of atmega328. I'm using 5v to power both boards and 3-5v coming from my sensors and switch to input HIGH value to the input pins of atmega328. I'm also done with my codes but I don't know if it is really correct because I'm not getting the desired result.
Here's the code:
int pin3 = 8;
int pin4 = 9;
int pin5 = 10;
Serial.begin(2400); //Baud rate of the GSM/GPRS Module
Serial.print("\r");
pinMode(pin3,INPUT);
pinMode(pin4,INPUT);
pinMode(pin5,INPUT);
if(digitalRead(pin3) == HIGH)
level1_text();
else if (digitalRead(pin4) == HIGH)
level2_text();
else if (digitalRead(pin5) == HIGH)
final_text();
Serial.print("AT\r");
void level1_text()
Serial.print("AT+CMGF=1\r");
Serial.print("AT+CMGS=\"+639088667253\"\r"); //Number to which you want to send the sms
Serial.print("Water Sensor Level 1"); //The text of the message to be sent
Serial.write(0x1A);
delay(2000);
void level2_text()
Serial.print("Water Sensor Level 2"); //The text of the message to be sent
Serial.write(0x1A);
delay(2000);
void final_text()
Serial.print("Final"); //The text of the message to be sent
Serial.write(0x1A);
delay(2000);
I've tried other input pins but still same result. What's the real problem is that, every time I connect a connector pin to the declared input pins of atmega328 on my codes. As in only connector pins, no other connections, just connector pins, it sends an sms. And based on my code, it will just send an sms message if there's an input of a HIGH value. But i don't get it, I didn't give any supply for it to sense a HIGH value just connector pins :(. I don't know if I have a wrong codes or it is a board problem or I miss any connections on the both boards. So please help me. And another problem, I bought another atmega328 to test if I have bad board or not but my program is not uploading. I waited for how many minutes but it didn't finish uploading the codes or sometimes I got an error:
avrdude: stk500_getsync(): not in sync: resp=0x00
What should I do? Thanks for having a time reading my post. And hope you can help me, It will be much appreciated. Thanks again and God Bless you!
