Problem Serial Buffer
Hi friends!
I have a problem with serial in Arduino.
I am using a sensor RS232 and send to arduino to display.
The problem is, while the sensor is working, it loading data and after stoped, it show the data in my display.
I am want show in real time, but it is not working.
I am use a simple code serial.read();
Who may help me?
Thanks!
What you need to do is
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
If that does not solve your problem you need to post your program.
...R
Hi.
Thanks.
My Code:
String readStringSerial()
  String content = "";
  char chart;
  while (Serial1.available() >0)
    chart = Serial1.read();
    Serial.print (chart);
        if (chart != '\r')
          content.concat(chart);
        if (chart == '\r')
          return content;
    delay(1);
I want interrupt the serial every 0,5 seconds to show the data sensor to my display.
Yeah you definitely need
Saulo_GPU:
My Code:
This is getting very tiresome. If you want help post a complete program.
And tell us in detail what it does when you run the program, and what you want it to do that is different.
...R
  int i=0;
  String conteudo = "";
  char caractere;
       if (currentMillis - previousMillis > interval)
      Serial1.read();
    caractere = Serial1.read();
    Serial.print (caractere);
      if (caractere != '\r')
      conteudo.concat(caractere);
      if (caractere == '\r')
      return conteudo;
    delay(1);
  now = time(NULL);
  pinMode(12, OUTPUT);
  pinMode(13,OUTPUT);
  digitalWrite(13,HIGH);
  Serial1.begin(1200);
  delay(200);
  String dataString = "", dataString2 = "";
  if (Serial1.available() >0)
    received = readStringSerial();
    if (received[0] == '+')
      int Hundred = (received[1] - '0') * 100;
      int Ten =  (received[2] - '0') * 10;
      int Unity = (received[3] - '0');
      result = Hundred + Ten + Unity;
      sample = result;
      i++;
      if (sample > velomaxd)
    {  sprintf(buffer, "%03d", sample);
       Serial1.print(String("SetDisplay") + (buffer) + (";\r"));   //display
       if (sample <= velomaxd)
    sample = 0;
    Serial.println("Interno: "+ dataString);
    Serial.println(i);
I am reading a doppler sensor RS232.
The object moves and the sensor sends velocity data to TX while the object are moving in front of the sensor.
The problem is:
Arduino not send the data to my display while the sensor is reading ( while the object is aproaching).
I need that, in real time while sensor is reading, send velocity data to Arduino, that receive this data and send to my display.
Try the code in the link I gave you in Reply #2. The second example will probably do most of what you want.
While it is unlikely to be the immediate cause of the problem it is not a good idea to use the String (capital S) class on an Arduino as it can cause memory corruption in the small memory on an Arduino. This can happen after the program has been running perfectly for some time. Just use cstrings - char arrays terminated with '\0' (NULL).
...R
The problem is:
Your code does not compile for a start.
Robin2:
...R
Hey.
I have tested this code.
The result is the same.
It prints after the sensor stops sending data.
When I read the RX of the sensor. Every 0.5 seconds, it send the velocity of object and carry to the next line until the object exit the detection field.
Using the Serial.
When I read the serial using Arduino. While the object is moving, nothing is showed. But when the object exit the detection field, the sensor stops sending data. The Arduino write all data in Serial.
Saulo_GPU:
Hey.
Then I can't figure what you want it to do.
Please post a link to the datasheet for the sensor so we can get at the facts.
...R
Hey Robin.
Thanks again.
I've maked that video:
I've simulated using my hand, but let imagine when the object is a car with distance of 5 meters.
While the sensor write in his TX with the instant velocity every 0,5 seconds. The Arduino wait the car pass the sensor to read all instant velocitys.
The Sensor is:
Doopler DR500
What exactly is the loop variable ( i ) used for?
What exactly is the readStringSerial() function variable ( i ) used for?
When is variable ( velomaxd ) ever not 0
When is variable ( interval ) ever not 0
When was received[3] ever declared? // edit you used received[3] so when was received[4] declared?
Sorry, but I don't know what your video is trying to show.
The datasheet that you linked to says
Speed data is output serially in mph as three ASCII digits in the following format:
nnn\n\r
where:
nnn : The three digit ASCIII speed digits in mph
\n\r : A new line followed by a carriage return character
The second example in my tutorial should receive that data and print each item as it is received without needing any changes to the program.
As written my example uses the \n as the end-marker and it will treat the \r as the first character of the next message.
As I said earlier, if that is not suitable you will need to explain in detail what you want to happen that is different.
...R
Slumpert:
Hey man.
Some variable was created for tests.
Sorry Robin.
In that video. On the left is Arduino Serial Out and on the Right the Serial Out of the sensor.
When a object moves in front of the sensor, the sensor write in its TX every 0,5 seconds the instant velocity of the object.
When I read this sensor of Arduino, Arduino dosen't read and write every 0,5 seconds in Serial. Arduino waits the sensor stops reading then it writes all data in the Serial.
Arduino read all data in Serial1(sensor) and write once in Serial.
I may make another video.
Saulo_GPU:
Post the program that displays the behaviour you have just described and post (as text) an example of the output from that program.
...R
PS. I don't think another video is worthwhile. Apart from anything else the text was too small to read.
