Problem: Serial COM Port Closes
Hello all, I would like to post a problem I have to see if someone could help me.
I have an Arduino BT and made a sketch tat recieves a number through bluetooth, sends that reading back to the computer, and uses that value to move some servos. The problem is that every second or third number I send, the COM port closes, and the connection is lost. If I close and reopen the serial monitor, the port opens again, but closes after just a few inputs. If I don’t send data the port never closes. Am I doing something wrong? Or perhaps it’s my bluetooth dongle?.. Thanks alot for any help you could provide.
#include <ServoMultiPin.h>
Servo frontservo;
Servo rightservo;
Servo leftservo;
int read1;
  frontservo.attach(9);
  rightservo.attach(8);
  leftservo.attach(7);
  Serial.flush();
void loop(){
  if (Serial.available() > 0 ){
    read1 = Serial.read() - 48;
    delay(200);
    Serial.print(read1);
    delay(200);
    if(read1 == 0){
      frontservo.write(90);
      rightservo.write(90);
      leftservo.write(90);
    else if(read1 == 1){
      rightservo.write(180);
      leftservo.write(0);
      for(int i=0; i<50; i++){
        Servo::refresh();
        delay(50);
    else if(read1 == 2){
      frontservo.write(60);
      rightservo.write(96);
      leftservo.write(96);
        Servo::refresh();
        delay(50);
    else if(read1 == 3){
      frontservo.write(120);
      rightservo.write(84);
      leftservo.write(84);
        Servo::refresh();
        delay(50);
   Serial.flush();
Are you powering the servos from Arduino ?
If so, you are probably drawing too much current, and Arduino resets, this is what you experience as com port close down.
Thanks for the reply.
I ran it a couple of times with all the servos disconnected from the Arduino (nothing connected to the Arduino), and with new batteries (3V), and still the same behavior. I also tried a different serial monitor I downloaded, and different baud rates, but the same thing happens. :'(
But It works properly just with a Serial.print("hello world"); sketch? or fail too?
I started again with a simple hello world program and it did not disconnect. I added features until it disconnected again, and I pinpointed the problem: the refresh function. If I use the refresh function the connection is lost. I'm searching to see if I'm using it wrong...
Don’t use the servo library, it just bloats your code.
Just use,
#define CENTER_RANGE 5
// Speed = 0 to 100
// Forward = true or false
// ServoPin = pin attached to control
void servo_control(int speed, bool forward, int servoPin)
    analogWrite(servoPin,(speed>CENTER_RANGE || speed<-CENTER_RANGE) ? map(-speed * (forward ? 1:-1),-100,100,135,225):0);
Gracias eried!
Can this be used with more than two servos?
Of course (max 6 servos), but only use the pin 3, 5, 6, 9, 10 or 11
