Problem - show values in window, read from Arduino.
Hi.
I have a problem to show the values of Temperature in a window on Processing.
In Arduino i'm printing the code:
 Serial.print(tempC, 1);
          Serial.print("\t");
          Serial.print(tempK, 1);
          Serial.print("\t");
          Serial.print(tempF, 1);
In Processing i'm saving the temperature to a notepad in this format:
    2013/8/28    16:31:52    25.6    298.7    78.1
    2013/8/28    16:31:53    25.9    299.1    78.7
    2013/8/28    16:31:54    25.9    299.1    78.6
But when i show the sensorReading in a Window, it's show like this:
    25.9299.178.6
it's printing the temperature in Celsius, Kelvin and Fahrenheit bonded.
I'm using this code:
    import processing.serial.*;
    Serial myPort;
    String sensorReading="";
    PFont font;
    PrintWriter output;
      size(600, 300);
      myPort = new Serial(this, "COM4", 9600);
      myPort.bufferUntil('\n');
      font = createFont(PFont.list()[4], 36);
      textFont(font);
      output = createWriter( "C:/Users/alunosdefi/Desktop/data.txt" );
    void draw()
    void serialEvent (Serial myPort)
     sensorReading= myPort.readStringUntil('\n');
      if(sensorReading != null)
       sensorReading=trim(sensorReading);
      output.println(year() + "/" + month() + "/" + day() + "\t" + hour() + ":" + minute() + ":" + second() + "\t" + sensorReading);
      output.flush();
     writeText("Temperatura:  " + sensorReading + " ºC");
    void writeText(String textToWrite)
      background(180);
      fill(127,0,0);
      text(textToWrite, width/20, height/2);
Can someone tell me how I can only display temperature in ºC in the window?
thank you
So, sensorReading is ALL the data read from the serial port.
Fortunately, Processing has a split() method in the String class that can split the String into an array of Strings. Then, you can use just the one you want.
I change some code: this is my new variables:
String imprimir="";
String sensorReadingT="";
float tempK=0;
float tempF=0;
and the code that i change:
imprimir =myPort.readStringUntil('\t'); because i do Serial.print(tempC) and after ("\t)
   if(imprimir != null)
   imprimir=trim(imprimir); //imprimir is the value of temperature in ºC
 tempK= Float.parseFloat(imprimir) + 275.15; //Converter to Kelvin
tempF= 1.8 * Float.parseFloat(imprimir) + 32; // Converter to ºF
String tempF1= nfc(tempF, 1); // i find this code in Processing Forum to print with only one decimal
String tempK1= String.format("%.1f", tempK); // i find this code too in other site
sensorReading= myPort.readStringUntil('\n'); //Read the ºC, "/t" and the word Alarme! (if temp>X or temp<Y)
It's printing to notepad and show only the temperature in ºC because in Arduino i only do the Serial.print of Temperature in ºC, and in Processing i'm converted to Kelvin and Fahrenheit.
( imprimir + "\t" + sensorReading + "\t" + tempK1 + "\t" + tempF1)
There is only a problem!!
it's printing the Temperature K and ºF with a "," and i pretend a dot "."
here's a example:
2013/8/29	18:39:30	25.7		300,9	78,3
2013/8/29	18:39:31	25.6		300,8	78,1
2013/8/29	18:39:32	25.6		300,8	78,1
2013/8/29	18:39:33	25.6		300,8	78,1
2013/8/29	18:39:34	25.6		300,8	78,1
2013/8/29	18:39:35	25.6		300,8	78,1
with the two codes that i found no one prints the value of K and ºF temperature with dot decimal separation..
Can someone HELP????
thanks!!
PS: i 'm converted the temperature ºC to K and ºF, because i read if less more prints in Arduino, better to processing read the Serial..
Do you agree????
That looks like a localization issue. When I ask Processing, using English as the local language, to print floats, it uses a decimal point, not a comma, as the separator.
You could use String methods to replace the ',' that nfc() and String.format() added to tempF1 and tempK1 with a '.', instead.
