what mean?? what i should do??
Hi @dieguitovalle. It will not be possible for us to help you with that problem based on such a vague description. Please provide a detailed explanation of what you mean by this, including:
- What did you do?
- What were the results you expected from doing that?
- What were the results you observed that did not match your expectations?
- Make sure to include the full and exact text of any error or warning message you might have encountered.
You can use debugging techniques to find the problem.
@dieguitovalle
Your post has been moved as it was in the wrong section of the forum.
You posted in a section that said it was NOT for your projects.
Please read the getting the most from this forum found at the start of each forum section.
