Problem starting with Arduino Uno
Hi!
I´m using Windows 7.
I have download IDE version 0022.
I have connect Arduino Uno and…
Green led y ON and L led is blinking on red.
When I try to upload from Arduino IDE I get the following error:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Any suggestion??
Thanks a lot.
Install the driver (.inf file) maybe ?
With the Arduino not connected, start the IDE. Which serial ports are listed under Tools + Serial port?
Quit the IDE. Plug the Arduino in, and restart the IDE. What serial ports are listed under Tools + Serial port? The Arduino is connected to the new serial port.
No new serial ports? The driver is not installed correctly.
“Windows update” understand it´s an Arduino Uno and it tries to install the driver but it can´t. Windows can´t find it.
I have try to install manually driver located in arduino_home/drivers but it is not compatible.
I have intalled on Ubuntu without any problem but I prefer to work on the PC instead the on the laptop (who has Ubuntu).
Where can I get de correct driver?
When asked to select a folder, did you select the drivers folder or the ftdi folder inside the drivers folder?
