[PROBLEM] Store received SMS phone number
Hello i have a gsm/gps/gprs shield connected to arduino and i would like to store the phone number from a new message that the arduino receives to use it later.
my code on loop is this:
  if(GSM.available()>0) //If there is stuff in the buffer
    textMessage = GSM.readString(); // Get the new message
    Serial.print(textMessage); // Print the new message
  if(textMessage.indexOf("+3069")>=0) // if it has phone number info
    Serial.println("Number found");
    textMessage.toCharArray(findingNumber, 80); //convert the string to char array so i can search it and store the phone number
    i=0;
    Serial.println(findingNumber); //print the char array to check if it is the same as the string
    while(i<80 || NumberFound == true) // start scanning every char of the array
      if ((findingNumber[i] == "+") && (findingNumber[i+1] == "3") && (findingNumber[i+2] == "0")) // if it finds +30 which is how the phone number starts
        j=0;
        while (j<13) //  (phone number has 13 digits)
          Number[j] = findingNumber[i]; // store the phone number in a seperated char array
          j++;
          i++;
        NumberFound = true; // boolean to stop the outside loop if phone number is found
        Serial.print("here is ur number ");
        Serial.print(Number); // print the seperated phone number
      i++;
i attached a pic with serial monitor results.
basically the "if ((findingNumber == "+") && ..."
doesnt return true to store the number .
why though???
    i=0;
I don't see findingNumber being printed, so there is something wrong with the conversion of the String to the char array.
Why are you reading the message as a String? Why not read it as a char array to begin with.
I guess the tochararray doesn't work as I expected?
I'm kinda noob to these stuff .
Can you show me how to read it as a char array from the beginning so I don't have to do this conversion ?
Its wise to avoid String object on small microprocessors like Arduino. See The Evils of Arduino Strings.
It is better to use c-strings which are null terminated character arrays and the c-string character array functions designed to manipulate them.
This uses .readBytes to put the gsm message into a character array and null terminates it. Then, strstr to set a pointer to any match, and then strncpy to grab the number after the match.
if (GSM.available() > 0) //If there is stuff in the buffer
    char textMessage[100] = {};
    char number[14] = {}; //13 chars + null
    //textMessage = GSM.readString(); // Get the new message
    byte numChars = GSM.readBytes(textMessage, 100);//.readBytes returns number read
    textMessage[numChars] = '\0';//null Terminator
    Serial.println(textMessage); // Print the new message
    char* pch = (strstr(textMessage, "+3069"));
    if (pch)
      strncpy(number, pch, 13);//copy 13 characters after pointer into number
      Serial.println(number);
      Serial.println("Number not found");
If this snippet does not work as expected, post your entire code.
Thanks for everything !
It works perfectly!
I even adjusted it to my whole code to do other several actions where i was using the same string and all work fine!
