Problem to code tactile on tft screen ILI9481
Hi guys
Im trying to develop a code for using tactile of my screen Ili9481 https://fr.aliexpress.com/item/3-2-3-5-pouces-480-320-TFT-LCD-Module-cran-D-affichage-ILI9481-ILI9486-Contr/32917044135.html?spm=a2g0w.search0104.3.2.52c02ad1UADcRA&transAbTest=ae803_3&ws_ab_test=searchweb0_0%2Csearchweb201602_2_10065_10068_319_10892_317_10696_5735515_453_10084_454_10083_10618_431_10304_10307_10820_10821_537_10302_536_10843_10059_10884_5736015_10887_100031_321_322_10103_5736115-10892%2Csearchweb201603_56%2CppcSwitch_0&algo_pvid=e16d8564-a3b5-4410-849c-722ddd36fe99&algo_expid=e16d8564-a3b5-4410-849c-722ddd36fe99-0 on my Arduino mega 2560
But i dont have any result, my screen is only white, here is the code that i tried...
// UTouch_QuickPaint (C)2013-2014 Henning Karlsen
// web: Electronics - Henning Karlsen
// This program is a quick demo of how to use the library.
// This program requires the UTFT library and a display
// module with at least 320x240 pixels resolution.
// It is assumed that the display module is connected to an
// appropriate shield or that you know how to change the pin
// numbers in the setup.
#include <UTFT.h>
#include <UTouch.h>
// Initialize display
// Set the pins to the correct ones for your development board
// Standard Arduino Uno/2009 Shield : ,19,18,17,16
// Standard Arduino Mega/Due shield : ,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Due : ,25,26,27,28
// Teensy 3.x TFT Test Board : ,23,22, 3, 4
// ElecHouse TFT LCD/SD Shield for Arduino Due : ,22,23,31,33
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(ILI9481,38,39,40,41); //3.5" TFTLCD for arduino 2560 from mcufriend.com
// Initialize touchscreen
// Standard Arduino Uno/2009 Shield : 15,10,14, 9, 8
// Standard Arduino Mega/Due shield : 6, 5, 4, 3, 2
// CTE TFT LCD/SD Shield for Arduino Due : 6, 5, 4, 3, 2
// Teensy 3.x TFT Test Board : 26,31,27,28,29
// ElecHouse TFT LCD/SD Shield for Arduino Due : 25,26,27,29,30
UTouch myTouch( 6, 5, 4, 3, 2);
// Declare which fonts we will be using
extern uint8_t BigFont[];
int color = 0;
word colorlist[] = {VGA_WHITE, VGA_BLACK, VGA_RED, VGA_BLUE, VGA_GREEN, VGA_FUCHSIA, VGA_YELLOW, VGA_AQUA};
int bsize = 4;
void drawColorMarkerAndBrushSize(int col)
myGLCD.setColor(VGA_BLACK);
myGLCD.fillRect(25, 0, 31, 239);
myGLCD.fillRect(myGLCD.getDisplayXSize()-31, 161, myGLCD.getDisplayXSize()-1, 191);
myGLCD.setColor(VGA_WHITE);
myGLCD.drawPixel(25, (col30)+15);
for (int i=1; i<7; i++)
myGLCD.drawLine(25+i, ((col
30)+15)-i, 25+i, ((col*30)+15)+i);
if (color==1)
myGLCD.setColor(colorlist[col]);
if (bsize==1)
myGLCD.drawPixel(myGLCD.getDisplayXSize()-15, 177);
myGLCD.fillCircle(myGLCD.getDisplayXSize()-15, 177, bsize);
myGLCD.InitLCD();
myGLCD.clrScr();
myGLCD.setFont(BigFont);
myTouch.InitTouch();
myTouch.setPrecision(PREC_HI);
myGLCD.drawLine(32,0,32,myGLCD.getDisplayYSize()-1);
myGLCD.drawLine(myGLCD.getDisplayXSize()-32,0,myGLCD.getDisplayXSize()-32,myGLCD.getDisplayYSize()-1);
myGLCD.print("C", myGLCD.getDisplayXSize()-24, 8);
myGLCD.print("L", myGLCD.getDisplayXSize()-24, 24);
myGLCD.print("E", myGLCD.getDisplayXSize()-24, 40);
myGLCD.print("A", myGLCD.getDisplayXSize()-24, 56);
myGLCD.print("R", myGLCD.getDisplayXSize()-24, 72);
myGLCD.print("+", myGLCD.getDisplayXSize()-24, 136);
myGLCD.print("-", myGLCD.getDisplayXSize()-24, 200);
myGLCD.fillRect(myGLCD.getDisplayXSize()-32,96,myGLCD.getDisplayXSize()-1,128);
myGLCD.drawLine(myGLCD.getDisplayXSize()-32,160,myGLCD.getDisplayXSize()-1,160);
myGLCD.drawLine(myGLCD.getDisplayXSize()-32,192,myGLCD.getDisplayXSize()-1,192);
myGLCD.drawLine(myGLCD.getDisplayXSize()-32,224,myGLCD.getDisplayXSize()-1,224);
for (int i=0; i<8; i++)
myGLCD.setColor(colorlist*);*
_ myGLCD.fillRect(0, (i*30), 24, (((i+1)*30)-1));_
  • drawColorMarkerAndBrushSize(color);*
  • long x, y;*
  • while (myTouch.dataAvailable() == true)*
  • myTouch.read();*
  • x = myTouch.getX();*
  • y = myTouch.getY();*
  • if ((x!=-1) and (y!=-1))*
  • if (x>(31+bsize) and (x<myGLCD.getDisplayXSize()-(31+bsize)))*
  • if (bsize==1)*
  • myGLCD.drawPixel(x, y);*
  • else*
  • myGLCD.fillCircle(x, y, bsize);*
  • else*
  • if (x<(30+bsize))*
  • if (y<240)*
  • color = y / 30;*
  • while (myTouch.dataAvailable()) {};*
  • delay(50);*
  • else*
  • if (y<96)*
  • myGLCD.setColor(VGA_BLACK);*
  • myGLCD.fillRect(33, 0, myGLCD.getDisplayXSize()-33, myGLCD.getDisplayYSize()-1);*
  • myGLCD.setColor(colorlist);*
  • if ((y>128) and (y<160))*
  • if (bsize<7)*
  • bsize++;*
  • delay(50);*
  • if ((y>160) and (y<192))*
  • bsize=4;*
  • delay(50);*
  • if ((y>192) and (y<224))*
  • if (bsize>1)*
  • bsize--;*
  • delay(50);*
    thank you in advance
Salut, c'est écrit dans la description que ce n'est pas un écran tactile..
