Problem to compile with ESP32 board after board support installation success
I need some help for the board ESP32 support in IDE.
I have installed the ESP32 board support with this tutorial:
it means i use this link :https://dl.espressif.com/dl/package_esp32_index.json
and then i activate the board support , and i works because i saw the differents ESP32 board in the menu. (Tools/board)
The problem is the following:
When i choose my board, (DOITESP32 dev1 for example) and if i try to compile a example i have a compile error : (for exemple if i compile "fading" the simply example provided with the IDE)
The following error message :
Arduino : 1.8.10 (Windows 10), Carte : "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"C:\Users\F085404\Documents\Perso\SmartHomeTrainerDIY\arduino-1.8.10\examples\03.Analog\Fading\Fading.ino: In function 'void loop()':Fading:30:34: error: 'analogWrite' was not declared in this scope analogWrite(ledPin, fadeValue); ^Fading:38:34: error: 'analogWrite' was not declared in this scope analogWrite(ledPin, fadeValue); ^exit status 1
'analogWrite' was not declared in this scopeCe rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
And if i choose a UNO board it's OK of course...
any suggestions??
thanks
Vincent
