Hey Arduino's Guys,
I'm a newbie in arduino programming . In fact I'd just begun a project with sensor.
I would like to save data, from the weatherShield, into the SDcard, and on a HTML page.
In fact, I succed to make these things separately. I succed to make work the SD card with the weatherShield, the ethernet connection with the EthernetShield and I succed to Put the name of file into the card online.
But when I try to make everythings work together, my code doesn't work anymore. I read and read again my code and I didn't find why! May be someone can help me with it.
When a test my code, I didn't have the Ethernet connection anymore and the command to open a file fail.
I 've wondering if the acces to the SDcard, when we put the Pin 1O( SS) as a output HIGH prevent a Ethernet connection?
Thanks a lot for you time.
My code:
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { ____________________}; // I put the right number here
byte ip[] = {___________ }; // And here
EthernetServer server(80);
Sd2Card card;
SdVolume volume;
SdFile root;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode()) {
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while(1);
File file= SD.open("AAA.txt");
if (file) {
Serial.println(file.read());
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
// breadboards. use SPI_FULL_SPEED for better performance.
pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
digitalWrite(10, HIGH); // but turn off the W5100 chip!
if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
// initialize a FAT volume
if (!volume.init(&card)) error("vol.init failed!");
PgmPrint("Volume is FAT");
Serial.println(volume.fatType(),DEC);
if (!root.openRoot(&volume)) error("openRoot failed");
// list file in root with date and size
PgmPrintln("Files found in root:");
root.ls(LS_DATE | LS_SIZE);
// Recursive list of all directories
PgmPrintln("Files found in all dirs:");
root.ls(LS_R);
PgmPrintln("Done");
// Debugging complete, we start the server!
Ethernet.begin(mac, ip);
server.begin();
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if we've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so we can send a reply
if (c == '\n' && current_line_is_blank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
// print all the files, use a helper to keep it clean
//ListFiles(client, 0);
client.println("<h2>Files:</h2>");
if (c == '\n') {
// we're starting a new line
} else if (c != '\r') {
// we've gotten a character on the current line
current_line_is_blank = false;
// give the web browser time to receive the data
delay(1);
client.stop();
void ListFiles(EthernetClient client, uint8_t flags) {
// This code is just copied from SdFile.cpp in the SDFat library
// and tweaked to print to the client output in html!
dir_t p;
root.rewind();
while (root.readDir(p) > 0) {
// done if past last used entry
if (p.name[0] == DIR_NAME_FREE) break;
// skip deleted entry and entries for . and ..
if (p.name[0] == DIR_NAME_DELETED || p.name[0] == '.') continue;
// only list subdirectories and files
if (!DIR_IS_FILE_OR_SUBDIR(&p)) continue;
// print file name with possible blank fill
//root.printDirName(*p, flags & (LS_DATE | LS_SIZE) ? 14 : 0);
for (uint8_t i = 0; i < 11; i++) {
if (p.name[i] == ' ') continue;
if (i == 8) {
client.print('.');
client.write(p.name[i]);
if (DIR_IS_SUBDIR(&p)) {
client.print('/');
// print modify date/time if requested
if (flags & LS_DATE) {
root.printFatDate(p.lastWriteDate);
client.print(' ');
root.printFatTime(p.lastWriteTime);
// print size if requested
if (!DIR_IS_SUBDIR(&p) && (flags & LS_SIZE)) {
client.print(' ');
client.print(p.fileSize);
client.println("
