Problem to read SMS
I use the code from http://www.instructables.com/id/Control-the-relays-via-GPRS-SMS/?ALLSTEPS to control two LEDs with SMS commands.
It has worked!
Suddenly, I can only control the Arduino circuit with SMS containing 3 characters.
If I connect the GSM shiled to a serial monitor, I see SMS containing more than three characters.
It seems that something is wrong in the code or something has happened to the Arduino.
A few weeks ago, everything worked and I have not changed in the code ...
What could be wrong?
#include <SoftwareSerial.h>
//http://www.instructables.com/id/Control-the-relays-via-GPRS-SMS/?ALLSTEPS
// EN: String buffer for the GPRS shield message
String msg = String("");
// EN: Set to 1 when the next GPRS shield message will contains the SMS message
int SmsContentFlag = 0;
//control pins of relay.
int GreenLed=6;
int RedLed=7;
  Serial.begin(19200);                 // the GPRS baud rate
  // Initialize  PINs
  pinMode( 6, OUTPUT );
  pinMode( 7, OUTPUT );
  digitalWrite( 6, LOW );
  digitalWrite( 7, LOW );
 Serial.println( "AT+CMGF=1" );
 delay(200);
    char SerialInByte;
    if(Serial.available())
        SerialInByte = (unsigned char)Serial.read();
       delay(5);
        // EN: Program also listen to the GPRS shield message.
       // EN: If the message ends with <CR> then process the message
        if( SerialInByte == 13 ){
          // EN: Store the char into the message buffer
          ProcessGprsMsg();
         if( SerialInByte == 10 ){
            // EN: Skip Line feed
         else {
           // EN: store the current character in the message string buffer
           msg += String(SerialInByte);
// EN: Make action based on the content of the SMS.
//     Notice than SMS content is the result of the processing of several GPRS shield messages.
void ProcessSms( String sms ){
   if( sms.indexOf("onc") >= 0 ){
    digitalWrite(  GreenLed, HIGH );
  if( sms.indexOf("ond") >= 0 ){
    digitalWrite(  RedLed, HIGH );
  if( sms.indexOf("offc") >= 0 ){
    digitalWrite(  GreenLed, LOW );
  if( sms.indexOf("offd") >= 0 ){
    digitalWrite(  RedLed, LOW );
 Serial.println("AT+CMGD=1,4"); // delete last SMS
// EN: Request Text Mode for SMS messaging
void GprsTextModeSMS(){
void GprsReadSmsStore( String SmsStorePos ){
  Serial.print( "AT+CMGR=" );
  Serial.println( SmsStorePos );
// EN: Clear the GPRS shield message buffer
void ClearGprsMsg(){
  msg = "";
// EN: interpret the GPRS shield message and act appropiately
void ProcessGprsMsg() {
  if( msg.indexOf( "Call Ready" ) >= 0 ){
   //  Serial.println( "*** GPRS Shield registered on Mobile Network ***" );
     GprsTextModeSMS();
  // EN: unsolicited message received when getting a SMS message
  if( msg.indexOf( "+CMTI" ) >= 0 ){
   //  Serial.println( "*** SMS Received ***" );
     // EN: Look for the coma in the full message (+CMTI: "SM",6)
     //     In the sample, the SMS is stored at position 6
     int iPos = msg.indexOf( "," );
     String SmsStorePos = msg.substring( iPos+1 );
   //  Serial.print( "SMS stored at " );
  //   Serial.println( SmsStorePos );
     // EN: Ask to read the SMS store
     GprsReadSmsStore( SmsStorePos );
  // EN: SMS store readed through UART (result of GprsReadSmsStore request)
  if( msg.indexOf( "+CMGR:" ) >= 0 ){
    // EN: Next message will contains the BODY of SMS
    SmsContentFlag = 1;
    // EN: Following lines are essentiel to not clear the flag!
    ClearGprsMsg();
    return;
  // EN: +CMGR message just before indicate that the following GRPS Shield message
  //     (this message) will contains the SMS body
  if( SmsContentFlag == 1 ){
 //   Serial.println( "*** SMS MESSAGE CONTENT ***" );
 //   Serial.println( msg );
 //   Serial.println( "*** END OF SMS MESSAGE ***" );
    ProcessSms( msg );
  ClearGprsMsg();
  // EN: Always clear the flag
  SmsContentFlag = 0;
