Ken76:
Here are two links about some info about Lego Power Function. I couldn’t find more info.
I had hoped that others had come along who know more about this than my near-zero knowledge.
From Github this is the .h file
LEGO Power Functions protocol for the arduino.
20-04-2009
Version 1.1
Changelist:
- Changed the timing in oscillationWrite from 13us to 9us.
- Forgot to set the ir-pin to OUTPUT
- added support for SingleOutput the "Clear - Set - Toggle"
This code is based on the code of Bob Kojima 01-19-2008
I have modified it to work on the Arduino.
Roland Wiersma
#ifndef legopowerfunctions_h
#define legopowerfunctions_h
#include <Arduino.h>
//SinglePin & SingleOutput modes
#define CONTINUOUS 0x2
#define TIMEOUT 0x3
#define PWM 0x0
#define CST 0x2 //Clear - Set - Toggle
//ComboPWM & SingleOutput pwm steps
#define PWM_FLT 0x0
#define PWM_FWD1 0x1
#define PWM_FWD2 0x2
#define PWM_FWD3 0x3
#define PWM_FWD4 0x4
#define PWM_FWD5 0x5
#define PWM_FWD6 0x6
#define PWM_FWD7 0x7
#define PWM_BRK 0x8
#define PWM_REV7 0x9
#define PWM_REV6 0xA
#define PWM_REV5 0xB
#define PWM_REV4 0xC
#define PWM_REV3 0xD
#define PWM_REV2 0xE
#define PWM_REV1 0xf
//SingleOutput Clear - Set - Toggle steps
#define CL_C1_CL_C2 0x0
#define ST_C1_CL_C2 0x1
#define CL_C1_ST_C2 0x2
#define ST_C1_ST_C2 0x3
#define INC_PWM 0x4
#define DEC_PWM 0x5
#define FULL_FWD 0x6
#define FULL_REV 0x7
#define TOG_FWD_REV 0x8
//ComboMode steps
#define RED_FLT 0x0
#define RED_FWD 0x1
#define RED_REV 0x2
#define RED_BRK 0x3
#define BLUE_FLT 0x0
#define BLUE_FWD 0x4
#define BLUE_REV 0x8
#define BLUE_BRK 0xC
//channels
#define CH1 0x0
#define CH2 0x1
#define CH3 0x2
#define CH4 0x3
//SinglePin & SingleOutput output
#define RED 0x0
#define BLUE 0x1
//SinglePin functions
#define NO_CHANGE 0x0
#define CLEAR 0x1
#define SET 0x2
#define TOGGLE 0x3
//SinglePin pin
#define PIN_C1 0x0
#define PIN_C2 0x1
class LEGOPowerFunctions
private:
void pf_send(int code1, int code2);
void oscillationWrite(int pin, int time);
void start_stop_bit();
void message_pause(int channel, int count);
public:
LEGOPowerFunctions(int IR_Pin);
void SingleOutput(int mode, int step, int output, int channel);
void SinglePin(int mode, int function, int pin, int output, int channel);
void ComboMode(int blue_speed, int red_speed, int channel);
void ComboPWM(int blue_pwm, int red_pwm, int channel);
#endif
and this is the .cpp file
20-04-2009
Version 1.1
Changelist:
Roland Wiersma
#include "legopowerfunctions.h"
int _IR_Pin;
int toggle[4] = {0, 0, 0, 0};
int delay_code1, delay_code2, messagecount = 0;
LEGOPowerFunctions::LEGOPowerFunctions(int IR_Pin) {
_IR_Pin = IR_Pin;
pinMode(IR_Pin, OUTPUT);
void LEGOPowerFunctions::SingleOutput(int mode, int step, int output, int channel) {
int nib1, nib2, nib3, nib4;
//set nibs
nib1 = toggle[channel] | channel;
nib2 = 0x4 | mode | output;
nib3 = step;
nib4 = 0xf ^ nib1 ^ nib2 ^ nib3;
message_pause(channel, messagecount);
pf_send(nib1 << 4 | nib2, nib3 << 4 | nib4);
if (toggle[channel] == 0)
toggle[channel] = 8;
toggle[channel] = 0;
void LEGOPowerFunctions::SinglePin(int mode, int function, int pin, int output, int channel) {
//set nibs
nib2 = 0x00 | mode;
nib3 = output << 4 | pin << 3 | function;
void LEGOPowerFunctions::ComboMode(int blue_speed, int red_speed, int channel) {
//set nibs
nib1 = channel;
nib2 = 0x01;
nib3 = blue_speed | red_speed;
void LEGOPowerFunctions::ComboPWM(int blue_pwm, int red_pwm, int channel) {
//set nibs
nib1 = 0x4 | channel;
nib2 = blue_pwm;
nib3 = red_pwm;
void LEGOPowerFunctions::pf_send(int code1, int code2) {
if (code1 == delay_code1 && code2 == delay_code2)
if (messagecount < 4)
messagecount++;
} else
delay_code1 = code1;
delay_code2 = code2;
messagecount = 0;
cli(); // make it uninterruptable
start_stop_bit();
int x = 128;
while (x) {
oscillationWrite(_IR_Pin, 156);
if (code1 & x) //high bit
delayMicroseconds(546);
else //low bit
delayMicroseconds(260);
x >>= 1; //next bit
x = 128;
while (x) {
if (code2 & x) // high bit
else //low bit
x >>= 1; //next bit
start_stop_bit();
sei();
void LEGOPowerFunctions::start_stop_bit() {
delayMicroseconds(1014);
The IR signal is 38Khz
1 pulse is 26 microseconds (1/1.000.000)
So the delay should be 13us, but because of internal delay 9us is more close.
I have timed it with a scope. 13us delay equals about 28khz.
10us is about 35khz. I have not timed 9us but i think its close.
void LEGOPowerFunctions::oscillationWrite(int pin, int time) {
for (int i = 0; i <= time / 26; i++) {
digitalWrite(pin, HIGH);
delayMicroseconds(9);
digitalWrite(pin, LOW);
void LEGOPowerFunctions::message_pause(int channel, int count) {
unsigned char a = 0;
if (count == 0)
a = 4 - channel;
else if (count == 1 || count == 2)
a = 5;
else if (count == 3 || count == 4)
a = (6 + 2 * channel);
delay(a * 16);
…R
