Problem to send and receive GPS with SMS
Hi everyone i found a program on arduino with SIM 908 GPS/GPRS/GSM but it’s not working.
The error:
C:\Users\Dorian\Desktop\TIPE\Tramme_GPGGA\Tramme_GPGGA.ino: In function ‘void loop()’:
C:\Users\Dorian\Desktop\TIPE\Tramme_GPGGA\Tramme_GPGGA.ino:257:50: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
If you have any questions about the program i can answer as fast as possible for me.
The program is linked to my post.
Thx everyone
Tramme_GPGGA.ino (7.79 KB)
The error:
That is NOT an error. It is a warning. It has been discussed too many times already.
Yes i know it but i didn't understand and how to resolve this warning on my program.
DorianJ78: Yes i know it but i didn't understand and how to resolve this warning on my program.
You don't NEED to.
If you WANT to, cast the string literal to a const char *, as any of the myriad of posts on this same topic would have told you to, if you'd bothered searching.
I have already done that but it's still not working, indeed the warning disappears. Sorry if i asked one more time on the forum but i thought that it was more responses about the warning which will solve my problem.
void send_string (char* numble,String string) { [u]is now[/u] void send_string (const char* numble,String string) {
I thought this warning was the cause of the dysfunction but it is not.
OK - this is how the code SHOULD have been posted (!)
I didn’t touch the indenting etc - just put it in tags…
/*     Programme perso pour utiliser le shield GPS_GSM de DFRobot       */
/*     tout en un.                                                      */
#include <SoftwareSerial.h>  // Uniquement pour le débogage.
#define gps_enable()    digitalWrite (4, LOW)
#define gps_disable()   digitalWrite (4, HIGH)
#define gsm_enable()    digitalWrite (3, LOW)
#define gsm_disable()   digitalWrite (3, HIGH)
#define COLLECTING 1
#define WAITING 0
#define DONE 2
#define LF 0x0a
#define CR 0x0d
SoftwareSerial mySerial(10, 11); // RX, TX (Uniquement pour le débogage).
int state;
int analogPin = 0;
String trame;
String str;
char inchar;
int ledpin = 13;
void start_gsm ()  // Fonction pour passer en mode GSM.
    gsm_enable ();
  delay(10);
  gps_disable ();
  delay (5000);
    delay (5000);
  delay (5000);
  Serial.println("AT+CMGD=1,4"); //Effacer tout les SMS en memoire.
  mySerial.println("startAT+CMGD=1,4");
void start_gps ()  // Fonction pour passer en mode GPS.
    gsm_enable ();
  delay(10);
    gps_disable ();
  delay (2000);
  delay (5000);
    delay (5000);
    mySerial.println ("waiting for GPS! ");
    Serial.println ("AT");
    mySerial.println ("Send AT");
    delay (2000);
      delay (2000);
    Serial.println ("AT+CGPSPWR=1");
    mySerial.println ("Send AT+CGPSPWR=1");
    delay (2000);
    Serial.println ("AT+CGPSRST=1");
    mySerial.println ("Send AT+CGPSRST=1");
    delay (2000);
    gsm_disable ();
    gps_enable ();
    delay (2000);
    mySerial.println ("$GPGGA information: ");
  /* Détection trame GPGGA        */
  trame = "";
  state = 0;
  while (true)
    if (Serial.available() > 0)
      char ch = Serial.read();
      if (ch=='
FAR, FAR too many delay() calls… who knows what serial messages were missed during those lost seconds!
A good idea to blank out your mobile number within posts - or ne’er-do-wells will blitz you with junk messages.
Those two send_string() functions cold be combined and make a lot more sense.
Another good starting point would be to change all the Strings into C-strings (char arrays) to make the memory footprint smaller and more stable.
        state = COLLECTING;
        trame = “”;
      else if (ch==CR || ch==LF)
        state = DONE;
      if (state==COLLECTING)
        trame += ch;
        mySerial.print(ch);
    if (state==DONE)
      if (trame.startsWith("$GPGGA")==true)
Décodage Trame GPGGA (Latitude et Longitude.                        /
        int Virg1 = trame.indexOf(’,’);  // On cherche les virgules de la trame.
        int Virg2 = trame.indexOf(’,’, Virg1 + 1 );
        int Virg3 = trame.indexOf(’,’, Virg2 + 1 );
        int Virg4 = trame.indexOf(’,’, Virg3 + 1 );
        int Virg5 = trame.indexOf(’,’, Virg4 + 1 );
        int Virg6 = trame.indexOf(’,’, Virg5 + 1 );
        String latitude = (trame.substring(Virg2+1,Virg4+1));
        String longitude = (trame.substring(Virg4+1,Virg6));
        latitude += longitude;
        if (Virg2 != Virg3 - 1)  //Si on a recu la latitude et longitude.
            mySerial.println(latitude);
            send_string(“0601005479”,latitude); //Envoi SMS coordonnées GPS.
            break;                // Remplacer XXXX par numero de telephone.
      state = WAITING;
  } // Fin while detection trame.
// Envoi d’un SMS (n° de tel + texte du SMS):
// Utilisé pour l’envoi coordonnées GPS
        char num_buf[25];
        sprintf (num_buf, “AT+CMGS=”%s"", numble);
        gsm_enable ();
        gps_disable ();
        delay (2000);
        Serial.println (“AT”);
        delay (200);
        delay (200);
        Serial.println (“AT+CMGF=1”);
        delay (200);
        Serial.println (num_buf);
        delay (200);
        Serial.println (string);
        Serial.write (26);  // Envoi du SMS (26).
// Utilisé pour l’envoi coordonnées valeur analogique.
void send_string2 (char* numble, char* volt) {
  char num_buf1[25];
  sprintf (num_buf1, “AT+CMGS=”%s"", numble);
  delay (2000);
  delay (200);
  delay (200);
  delay (200);
  Serial.println (num_buf1);
  delay (1000);
  Serial.println(volt);
  Serial.write (26);
  pinMode(3,OUTPUT);
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  mySerial.begin(115200);
  state = WAITING;
  digitalWrite (5, HIGH);
  delay (1500);
  digitalWrite (5, LOW);
  delay (1500);
    start_gsm();
void loop()  // Boucle principale.
Réception SMS                                                        /
  debut:
  if(Serial.available()>0)
    inchar=Serial.read();
    //mySerial.println(inchar);
    if(inchar==‘T’)
      delay(10);
      if (inchar==‘I’)  //GSM module recoit message,il envoie’+CMTI “SM”, 1’ sur le port série.
        delay(10);
        Serial.println(“AT+CMGR=1”);    // On demande l’envoi du SMS sur le port série.
                        //  Maintenant on va le lire
                                        // sur les lignes de progamme qui suivent.
        //mySerial.println(“AT+CMGR=1”);
        delay(10);
    else if (inchar==‘L’)                  // On test la première lettre du message.
      delay(10);
      if (inchar==‘H’)                    //On test la deuxiéme lettre du message.
        delay(10);
        digitalWrite(ledpin,HIGH);
        mySerial.println(“led on”);                        //Turn on led
        delay(50);
        Serial.println(“AT+CMGD=1,4”);                    //Delete all message
      if (inchar==‘L’)    //The SMS(“LH”) was display in the Serial port, and Arduino has recognize it.
        delay(10);
        digitalWrite(ledpin,LOW);
        mySerial.println(“led off”);                      //Turn off led
        delay(50);
      if (inchar==‘G’)    //The SMS(“LG”) was display in the Serial port, and Arduino has recognize it.
      {  //mySerial.println(“sms lg reconnu !!”);
        start_gps();
        //mySerial.println(“retour gps”);
        start_gsm();
        delay(50);
      if (inchar==‘A’)      //The SMS(“LA”) was display in the Serial port, and Arduino has recognize it.
        delay(10);
        int val =  analogRead(analogPin);
        delay(50);
        mySerial.println(val);
        float tension = val*5;
        tension = tension / 1023;
        char nu1[25];
        char tension_sortie[25];
        dtostrf(tension,4,3,nu1);
        sprintf (tension_sortie, “Tension A0 arduino = %s V”, nu1);
        send_string2(“0601005479”,tension_sortie); // Remplacer XXXXXXXX par votre N° de telephone.
        delay(50);
} // Fin void Loop.
FAR, FAR too many delay() calls... who knows what serial messages were missed during those lost seconds!
A good idea to blank out your mobile number within posts - or ne'er-do-wells will blitz you with junk messages.
Another good starting point would be to change all the Strings into C-strings (char[] arrays) to make the memory footprint smaller and more stable.
The code you posted does something. You forgot to tell us what it actually does.
You expect the code to do something. You forgot to tell us what you expect it to do.
How can you expect us to help you when you haven't told us what the problem is?
