I'm using arduino mega 2560 and GSM module(SIM9000).....
i want whenever i press button SMS will send on particular no. which is stored at 1st place in SIM card.
for this i'm using in interrupt to send SMS(event based).
i used <attachInterrupt(interrupt, ISR, mode)> for interrupt.
AND to send SMS i'm using lib. SIM908/sms... and method to send SMS is..< SendSMS(byte sim_phonebook_position,const char *message_str) >
But in this method lots of delay occurs, which r not good with interrupt (if i use methods with delays or wait resp. when i press button my device stop working. and same problem is hpng with the below described condition)... most of delay i removed or replaced by some other code, but i'm not able to remove one specific delay used in this method.... which is ....
char GSM::GetPhoneNumber(byte position, char *phone_number)
char ret_val = -1;
char *p_char;
char *p_char1;
if (position == 0) return (-3);
if (CLS_FREE != GetCommLineStatus()) return (ret_val);
SetCommLineStatus(CLS_ATCMD);
ret_val = 0; // not found yet
phone_number[0] = 0; // phone number not found yet => empty string
//send "AT+CPBR=XY" - where XY = position
_cell.print("AT+CPBR=");
_cell.print((int)position);
_cell.print("\r");
// 5000 msec. for initial comm tmout
// 50 msec. for inter character timeout
switch (WaitResp(5000, 50, "+CPBR")) {
case RX_TMOUT_ERR:
// response was not received in specific time
ret_val = -2;
case RX_FINISHED_STR_RECV:
// response in case valid phone number stored:
// <CR><LF>+CPBR: <index>,<number>,<type>,<text><CR><LF>
// <CR><LF>OK<CR><LF>
// response in case there is not phone number:
p_char = strchr((char *)(comm_buf), '"');
if (p_char != NULL) {
p_char++; // we are on the first phone number character
// find out '"' as finish character of phone number string
p_char1 = strchr((char *)(p_char), '"');
if (p_char1 != NULL) {
*p_char1 = 0; // end of string
// extract phone number string
strcpy(phone_number, (char *)(p_char));
// output value = we have found out phone number string
ret_val = 1;
case RX_FINISHED_STR_NOT_RECV:
// only OK or ERROR => no phone number
ret_val = 0;
SetCommLineStatus(CLS_FREE);
return (ret_val);
to get the phone number used this method but here wait resp. used in switch case.. and i tried a lot to replace it but didn't get any solution yet....
when i only send msg it is working properly in case of both number string and SIM_PhoneBookPosition_number by using these methods....
SendSMS(char *number_str, const char *message_str) ... for number string and
SendSMS(byte sim_phonebook_position,const char *message_str) ... for SIM_PhoneBookPosition_number
and with my sketch when i use number string instead of SIM_PhoneBookPosition_number, my sketch is working properly with other functions, but i want to send msg on SIM_PhoneBookPosition_number.
no, i was wrong that problem is with use of gps, coz when i try to connect to GPRS or internet connection with it same problem is occurring.. gsm not able to send sms at SIM_phonebook_number).
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include<SIM900.h>
#include <sms.h>
SoftwareSerial ss(12,13);
TinyGPS gps;
SMSGSM sms;
float flon;
float flat;
boolean started=false;
char str_lat[20],str_lon[20];
const int buttonPin = 2; // the number of the pushbutton pin
int buttonState = 0;
char data[20];
Serial.println("GSM Shield testing.");
if (gsm.begin(4800)) {
Serial.println("\nstatus=READY");
gsm.forceON(); //To ensure that SIM900 is not only in charge mode
started=true;
attachInterrupt(0,SMS,HIGH);
else Serial.println("\nstatus=IDLE");
if(started){
read_GPS();
void loop(){
if (TimeToSendSMS) {
TimeToSendSMS = false;
read_GPS();
SendTheSMS();
void read_GPS(){
ss.begin(9600);
bool newData = false;
unsigned long chars;
unsigned short sentences, failed;
// For one second we parse GPS data and report some key values
for (unsigned long start = millis(); millis() - start < 1000;){
while (ss.available()){
char c = ss.read();
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
if (newData){
float lat,lon;
gps.f_get_position(&flat, &flon);
Serial.print("LAT=");
Serial.println(lat=flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat,6);
Serial.print("LON=");
Serial.println(lon=flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon,6);
dtostrf(lat,3,6,str_lat); // double to string - dtostrf(double, signed char, unsigned char, char*)
dtostrf(lon,3,6,str_lon); // double to string
gps.stats(&chars, &sentences, &failed);
if (chars == 0)
Serial.println(F("** No characters received from GPS: check wiring **"));
void SMS() {
TimeToSendSMS = true;
void SendTheSMS(){
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH){
pinMode(buttonPin,INPUT);
sprintf(data, "***********/**********,%s,%s", str_lat, str_lon);
delay(100);
sms.SendSMS(1, data); // msg send on number at sim phonebook position 1.
//sms.SendSMS("**********",data); // msg on a 10 digits number string.
in this sketch see last two lines to send sms.... second last line is for SIM phonebook position 1.
and last is for number string.
sms.SendSMS("**********",data); is working properly ...but i want to use sms.SendSMS(1, data);, which is not properly working... i explained above what problem i'm facing with it.
I don't understand this. You are going to have to try harder, a lot harder, to make a coherent explanation of the problem.
ok.. i'll try my best to explain u.. see points with sketch posted.
i'm using SIM908 lib. in my sketch.(SIM908/SIM900/sms)
I want to send SMS (stored in a variable "data") on a number which is saved in SIM card.. But don't now why this method (sms.SendSMS(SIM_phonebook_position,text SMS)) is creating problem. and not sending SMS
3.when i use (sms.SendSMS(number string,text SMS)) in my sketch then my code works properly and give output as i want and send SMS on that number string.. but this method is not useful for my purpose. i just use this method in sketch to check where is problem.
When i comment(//) to read_GPS() .... sms.SendSMS(SIM_phonebook_position,text SMS ) is working properly and sending msg without any issue.
i have explained all the points.. now Please can u tell me why (sms.SendSMS(SIM_phonebook_position,text SMS)) is not working with read_GPS()?
