Problem to store my data to firebase using Nodemcu esp32 and DFrobot heart rate
Hi, im trying to send and store the value of my DFRobot Heartrate sensor to the real time firebase. I used it together with nodemcu esp 32. Unfortunately, I have read up alot online and I have no idea how to push the data to firebase. What I got are compilation error as i stated here. I’ve searched for quite awhile but ended up with nothing, Im fairly new to arduino and programming so please help me. I will be grateful to you. Thanks!
#define heartratePin 32
#include "DFRobot_Heartrate.h"
#include <WiFi.h>  //1. Include WiFi.h
#include "FirebaseESP32.h"  //2. Include Firebase ESP32 library (this library)
// Set these to run example.
#define FIREBASE_HOST "test.firebaseio.com"
#define FIREBASE_AUTH "hW8qlM48dGkxxxxxxxx1Pq5UD21YgPq2E0c"
#define WIFI_SSID "Gummya"
#define WIFI_PASSWORD "testtest1"
DFRobot_Heartrate heartrate(DIGITAL_MODE); ///< ANALOG_MODE or DIGITAL_MODE
FirebaseData firebaseData;  //3. Declare the Firebase Data object in the global scope
  initWifi();
  uint8_t rateValue;
  heartrate.getValue(heartratePin); ///< A1 foot sampled values
  rateValue = heartrate.getRate(); ///< Get heart rate value
    if(Firebase.setInt(firebaseData,"HeartBeat/BPM_data", rateValue)){
    //if (firebaseData.dataType()== "Int")
    Serial.println(rateValue);
  delay(20);
 void initWifi(){
    WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("Connecting to Wi-Fi");
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
    delay(300);
  Serial.print("Connected with IP: ");
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
  Firebase.reconnectWiFi(true);
  //Set database read timeout to 1 minute (max 15 minutes)
  Firebase.setReadTimeout(firebaseData, 1000 * 60);
  //tiny, small, medium, large and unlimited.
  //Size and its write timeout e.g. tiny (1s), small (10s), medium (30s) and large (60s).
  Firebase.setwriteSizeLimit(firebaseData, "tiny");
UPDATE: I managed to get the code works but I cannot get the heart beat bpm, it just shows ''wait for valid data" and 0 (I will attach it ) AND I am able to push the data into it.
Current problem: Heart beat BPM shows 0
got the FirebaseESP32.h library from → GitHub - mobizt/Firebase-ESP32: ESP32 Firebase RTDB Arduino Library
Any help will be highly appreciated. Thanks !
FirebaseESP32.h (112 KB)
