I have problem to store values to MySQL table from Arduino MKR 1010 Wifi.
I get the following message.
trying
got: 0 retrying
trying
got: 0 retrying
ERROR!
I have also tried to turn off firewall without success.
Is my code wrong? Can someone help me with this issue?
#include <Ethernet.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#include <MySQL_Encrypt_Sha1.h>
#include <MySQL_Packet.h>
#include <DHT.h>
#include <DHT_U.h>
#include <dht.h>
#include <WiFiNINA.h>
#include <wifiinfo.h>
byte mac_addr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
#define DHT22_PIN 7
#define DHTTYPE 22
DHT deviceMonitor(DHT22_PIN,DHTTYPE) ;
IPAddress server_addr(192,168,86,39); // IP of the MySQL *server* here
char user[] = "root"; // MySQL user login username
char password2[] = "test1234"; // MySQL user login password
char ssid[] = SECRET_SSID; // your network SSID (name)
char password[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the Wifi radio's status
float hum;
float temp;
float humError;
float tempError;
int checkTemp;
char INSERT_DATA[] = "INSERT INTO weather (temp, hum) VALUES ('%s','%d')";
char query[128];
char temperature[10];
EthernetClient client;
MySQL_Connection conn((Client *)&client);
//Initialize serial and wait for port to open:
while (!Serial); // wait for serial port to connect
Ethernet.begin(mac_addr);
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to network: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, password);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the data:
Serial.println("You're connected to the network");
Serial.println("----------------------------------------");
printData();
if (conn.connect(server_addr, 3306, user, password))
Serial.println("Mysql connection failed.");
delay(5000);
if (conn.connect(server_addr, 3306, user, password2)) {
MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
checkTemp = deviceMonitor.read(DHT22_PIN);
hum = deviceMonitor.readHumidity();
temp = deviceMonitor.readTemperature();
Serial.println((String)"Temperature: " + temp + " Celsius");
Serial.println((String)"Humidity: " + hum +"%");
sprintf(query, INSERT_DATA, temp, hum);
cur_mem->execute(query);
delete cur_mem;
Serial.println("Data recorded.");
delay(10000);
Serial.println("ERROR!");
void printData()
Serial.println("Board Information:");
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
Serial.println("Network Information:");
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.println(rssi);
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type:");
Serial.println(encryption, HEX);
b707
2
After connecting to MySQL you have to select database to work with. I don't see something similar in your code.
I granted full right to the user root in MySQL and now I got this error instead.
ERROR: Timeout waiting for client.
Error: -1 = Mysql connection failed.
And I also have selected hopefully the database in the right way!
char database[] ="spaceinformation";
if (conn.connect(server_addr, 3306, database, user, password))
Serial.println("Mysql connection successful.");
Can someone help me with this problem?
b707
4
Please show all your revised code
Here is the "full" code.
#include <DHT.h>
#include <DHT_U.h>
#include <dht.h>
#include <WiFiClient.h>
#define DHT22_PIN 7
#define DHTTYPE 22
float hum;
float temp;
float humError;
float tempError;
int checkTemp;
char query[128];
WiFiClient client;
delay(10000);
printData();
delay(5000);
if (conn.connect(server_addr, 3306, database, user, password2)) {
delete cur_mem;
delay(10000);
void printData()
Serial.println(ip);
b707
6
Could you show the output of your program?
When do you get the errors?
I get error message after the Serial.println("Mysql connection failed."); row from
the code below.
The output is
...trying...
Do you need more information?
b707
8
Did you try to connect to Mysql with same user, password and database manually, via telnet on port 3306?
Also
Did your board connects to the WiFi successfully?
Did you get the message:
What do your server logs say?
Also, by default, MySQL does not accept connections from external devices, you have to configure it to allow them.
A little late perhaps, but you got a typing error.
You request to open the connection with the wifi password. You should use password2
Anyways, it doesn't help
system
Closed
11
