Problem to upload sketch on arduino uno r3
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 1094 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM20 -b115200 -D -Uflash:w:C:\Users\Admin\AppData\Local\Temp\arduino_build_873938/FINALROTARO.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM20
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe9
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Invalid library found in C:\Program Files (x86)\Arduino\libraries\Alphanumeric_GPS_Clock-master: C:\Program Files (x86)\Arduino\libraries\Alphanumeric_GPS_Clock-master
Invalid library found in C:\Program Files (x86)\Arduino\libraries\Arduino-Traffic-Light-With-LED-Display-Timer-master: C:\Program Files (x86)\Arduino\libraries\Arduino-Traffic-Light-With-LED-Display-Timer-master
Invalid library found in C:\Program Files (x86)\Arduino\libraries\Arduino_GPS-master: C:\Program Files (x86)\Arduino\libraries\Arduino_GPS-master
Invalid library found in C:\Program Files (x86)\Arduino\libraries\GPS-Clock-master: C:\Program Files (x86)\Arduino\libraries\GPS-Clock-master
option enabled in File -> Preferences.
What made you think that it was appropriate to hijack a totally unrelated topic in the wrong section of the forum ?
Topic split from the original and moved
