Problem transmitting bytes via newsoftserial
Hello,
I'm using the following for example to transmit an array from one arduino nano to another using an RF transceiver (set at 9600 baud) using newsoftserial on pins 4,5 on both:
// transmitter
char tx_data[13] = {0x02,0x02,num_1,num_2,num_3,num_4,num_5,num_6,num_7,num_8,0x02,0x02,0x00};
transceiver.print(tx_data);
// receiver
if(transceiver.available()) {
    int index = 0;
    byte response[13];
    while(transceiver.available() > 0) {
      response[index] = transceiver.read();
      index++;
Each of the "num_x" is a dynamic value between 0-254. I had to put a leading/trailing "0x02,0x02" so on the receiver I can sort of do rx validation as too often there is junk data being received (possibly interference).
While this method works, the problem is I can't transmit faster than a 150 second delay between transmissions otherwise the receiving arduino doesn't read it for some reason.
I know there is limitations of speed at 9600 baud, but I'm wondering if anyone knows of a better way to send an array like that where it can send a bit quicker.
Any help would be appreciated.
I would not consider anything that requires a 2 and a half minute delay between transmissions as working, for any definition of working.
This could be a hardware problem, an interference problem, or a software problem on the sender or receiver. Determining where the problem is based on a code snippet on the sender is not possible.
You mean besides the obvious one of increasing the baud rate? Sending an array one byte at a time is the fastest way to send data. It isn't, obviously, possible to simultaneously transmit multiple bytes.
What happens if you hook the sending end up to a serial terminal? Do you still have the problem?
