Problem trying to find SD CARD holder
Hi all,
I am trying to find the exact part number of the SD card on the arduino board. The eagle BoM from the layout defines it as SDCARD-15TW-8821. I am not able to locate this on digikey. Does anyone know where this SD card holder is sourced from ? Is there any alternative part I can use to solder on to my board ?
Thanks
SD, or microSD?
I use this SD
http://www.digikey.com/product-detail/en/10067847-001RLF/609-3956-1-ND/2283479
and this microsSD
http://www.dipmicro.com/store/CON-MICROSD1
for new designs. I haven’t tried to replace one on some other existing design.
suhaskashyap:
Hi all,
Thanks
I have the same problem with usb connectors currently.
Even using the same supplier the footprint has changed slightly.
All I can do is go through the suppliers and compare footprints until I find one that fits.
If you are making your own boards why not alter the library part in Eagle to one that you can get
Perhaps it is just one of the billions of parts that DigiKey doesn't handle. A quick Google search turned up this source:
http://www.aliexpress.com/store/product/SDCARD-15TW-8821/126807_946510235.html (under $5, shipped)
johnwasser:
one of the billions of undocumented parts that have no traceability and from a supplier that can dry up at any time ?the problem with these parts is exactly what the OP stated. could not find it.
the better way is to list the supplier in the part so anyone can find the supplier. what would be even better is a link to the data sheet.
similar part is 2041021-4
digi key and mouser. can be found from multiple vendors
Thank you all for the help. I used Digikey part # WM19093CT-ND and moved my landing pads a little bit on eagle. I appreciate all your suggestions. Thanks
suhaskashyap how were able to add the WM19093CT-ND in the libraries of the EAGLE software.
