Problem Trying to Reset Webserver Form Values
Part 1 of 3
#include <Time.h>
#include <MemoryFree.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
// ethernet configuration
byte mac[] = {
  0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF };
byte ip[] = {
  192, 168, 0, 31 };  // ip in lan
byte gateway[] = {
  192, 168, 0, 1 };  // internet access via router
byte subnet[] = {
  255, 255, 255, 0 };  //subnet mask
EthernetServer server(80);  // port 80 is default for HTTP
// constants
const int AutoDownEnablePin = 6;  // enable autodown switch
const int DoorClosedPin = 7;  // door open switch
const int DoorOpenPin = 8;  // door closed switch
const int OpenCloseRelayPin1 =  9;
const int OpenCloseRelayPin2 =  5;
//const int LED = 9;  // led is connected to digital pin 9
const int timeZone = -5;  // Central Standard Time (USA)
// NTP Servers:
IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov
// IPAddress timeServer(132, 163, 4, 102); // time-b.timefreq.bldrdoc.gov
// IPAddress timeServer(132, 163, 4, 103); // time-c.timefreq.bldrdoc.gov
// variables
boolean DoorOpenState;
boolean DoorClosedState;
int DoorPosition;
boolean RelayEnable1;
String TimeString;
long TempTime;
int SecondsOpen = 0;
int MinutesOpen;
boolean AutoDownSwitch;
boolean AutoDownEnable;
int AutoDownMinutes;
char c = 0;  // received data
char command[2] = "\0";  // command
EthernetUDP Udp;
unsigned int localPort = 7777;  // local port to listen for UDP packets
  // initialize serial communication:
  // initialize IOs
  pinMode(AutoDownEnablePin, INPUT_PULLUP);
  pinMode(DoorOpenPin, INPUT_PULLUP);
  pinMode(DoorClosedPin, INPUT_PULLUP);
  pinMode(OpenCloseRelayPin1, OUTPUT);
  //pinMode(OpenCloseRelayPin2, OUTPUT);
  //pinMode(LED, OUTPUT);
  // initialize webserver
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  // initialize udp for time sync
  Udp.begin(localPort);
  setSyncProvider(getNtpTime);
time_t prevDisplay = 0; // when the digital clock was displayed
  updatetime();
  switchstatus();
  webserver();
  goto skipit;
  Serial.print(F("freeMemory()="));
  Serial.println(freeMemory());
  skipit:
void switchstatus()
  // read the state of the pushbutton value:
  DoorOpenState = digitalRead(DoorOpenPin);
  DoorClosedState = digitalRead(DoorClosedPin);
  // calculate door status
  if (DoorClosedState == 1 && DoorOpenState == 0){
    DoorPosition = 0;
  }  // door is open
  if (DoorClosedState == 0  && DoorOpenState == 0){
    DoorPosition = 1;
  }  // door is in middle position
  if (DoorClosedState == 0  && DoorOpenState == 1){
    DoorPosition = 2;
  }  // door is open
  if (DoorClosedState == 1  && DoorOpenState == 1){
    DoorPosition = 3;
  }  // ERROR unknown state
  goto skipit;
  //Print the results
  Serial.print(F("Closed="));
  Serial.print(DoorClosedState);
  Serial.print(F(",Open="));
  Serial.print(DoorOpenState);
  Serial.print(F(",Door="));
  Serial.print(DoorPosition);
  Serial.println();
  skipit:
