Problem trying to use led driver together with time clock and OLED screen
Hello everyone,
I am trying to connect a DS1307 time clock, an SSD1306_128X32 OLED screen and an P9813 led driver with my arduino mega. If I use only the the time clock and the screen, my code runs ok. But when I add also the led driver, arduino freezes after several steps of execution. I haven’t managed to locate the error yet. Any help it would be appreciated. My code is:
// RTC DS1307-------------------------------------------------------------------------------------
#include "RTClib.h"
RTC_DS1307 rtc;
#include <OneWire.h>
#include <DallasTemperature.h>  // DS18B20
#define DS18B20_PIN 11
OneWire oneWire(DS18B20_PIN);
DallasTemperature sensors(&oneWire);
//RGB-----------------------------------------------------------------------------------------
#include "RGBdriver.h"
#define CLK 13
#define DIO 12
RGBdriver Driver(CLK,DIO);
int R=0;
int G=0;
int B=0;
int m=20; // metriths
//int k=0;
//u8g2----------------------------------------------------------------------------------------
#include <Arduino.h>
#include <Wire.h>
#include <U8g2lib.h>
U8G2_SSD1306_128X32_UNIVISION_2_HW_I2C u8g2(U8G2_R0,SCL,SDA,U8X8_PIN_NONE);
int Xronos[]={23,59,59,0,0,0,0}; //Xronos
void setup () {
Wire.begin();
// DS1307-------------------------------------------------------------------------------------
 rtc.begin();
  // following line sets the RTC to the date & time this sketch was compiled
  // rtc.adjust(DateTime(F(_DATE_), F(_TIME_)));
  // This line sets the RTC with an explicit date & time, for example to set
  // January 21, 2014 at 3am you would call:
  //rtc.adjust(DateTime(2020, 4, 25, 2, 0, 0));
sensors.begin();  // DS18B20 start
Driver.begin();
Driver.SetColor(0, 0, 0);
Driver.end();
//Fan-----------------------------------------------------------------------------------------
pinMode(10,OUTPUT);
u8g2.begin();
u8g2.clearBuffer();
u8g2.clearDisplay();
void loop () {
Ora();
Screen();
Fan();
Ledstrip();
void Ora() {
DateTime now = rtc.now();
sensors.requestTemperatures();
Xronos[0]=now.hour();
Xronos[1]=now.minute();
Xronos[2]=now.second();
Xronos[6]=sensors.getTempCByIndex(0);
delay (150);
Serial.print(Xronos[0]);
Serial.print("---");
Serial.print(Xronos[1]);
Serial.print(Xronos[2]);
Serial.print(Xronos[3]);
Serial.print(Xronos[4]);
Serial.print(Xronos[5]);
Serial.println(Xronos[6]);
if (Xronos[6]==(-127)){Xronos[6]=0;}
void Screen(){
u8g2.clearBuffer();
int mo=((R+G+B)*100)/765;
u8g2.firstPage();
  do {
u8g2.setFont(u8g2_font_6x13_te );
u8g2.drawStr(76,32,"RGB:");
u8g2.setCursor(100,32);
u8g2.setFont(u8g2_font_fur11_tf);
u8g2.print(mo,DEC);
u8g2.print("%");
u8g2.setCursor(86,15);
u8g2.print(Xronos[6]);
u8g2.drawGlyph(106,15,0X00b0);
u8g2.drawStr(112, 15,"C");
u8g2.setFont(u8g2_font_fur20_tf);
  char buffer1[5];
  sprintf(buffer1, "%02d:%02d", Xronos[1], Xronos[2] );
u8g2.setCursor(0,26);
u8g2.print(buffer1);
  } while ( u8g2.nextPage() );
  delay(100);
u8g2.sendBuffer();  ;
void Ledstrip() {
if (Xronos[2]==0 || Xronos[2]==20 ||  Xronos[2]==40){
R=(R+m);
Xronos[3]=R;
  Driver.begin();
  Driver.SetColor(Xronos[3], Xronos[4], Xronos[5]);
  Driver.end();
delay(100);
if (R>255){R=0;}
void Fan(){
 if (Xronos[6]>24) {
 digitalWrite(10, HIGH);
 delay(150);
  {digitalWrite(10, LOW);}
