Problem UDP NTP CLIENT
Hello
The code example below works fine.
I would like to make IPtimeServer dynamic (I pass it through an eeprom reading), but I can not make it dynamic as variable.
how can I make it a variant that I load?
IPAddress timeServer(129, 6, 15, 28); // time.nist.gov NTP server
I tried:
IPAddress timeServer;
after passing it from the eeprom but it seems not to accept it
 Udp NTP Client
 Get the time from a Network Time Protocol (NTP) time server
 Demonstrates use of UDP sendPacket and ReceivePacket
 For more on NTP time servers and the messages needed to communicate with them,
 see http://en.wikipedia.org/wiki/Network_Time_Protocol
 created 4 Sep 2010
 by Michael Margolis
 modified 9 Apr 2012
 by Tom Igoe
 This code is in the public domain.
#include <SPI.h>
#include <WiFi.h>
#include <WiFiUdp.h>
int status = WL_IDLE_STATUS;
char ssid[] = "mynetwork";  //  your network SSID (name)
char pass[] = "mypassword";       // your network password
int keyIndex = 0;            // your network key Index number (needed only for WEP)
unsigned int localPort = 2390;      // local port to listen for UDP packets
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
WiFiUDP Udp;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv != "1.1.0") {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  Serial.println("Connected to wifi");
  printWifiStatus();
  Serial.println("\nStarting connection to server...");
  Udp.begin(localPort);
  sendNTPpacket(timeServer); // send an NTP packet to a time server
  // wait to see if a reply is available
  if (Udp.parsePacket()) {
    Serial.println("packet received");
    // We've received a packet, read the data from it
    Udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
    //the timestamp starts at byte 40 of the received packet and is four bytes,
    // or two words, long. First, esxtract the two words:
    unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
    unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
    // combine the four bytes (two words) into a long integer
    // this is NTP time (seconds since Jan 1 1900):
    unsigned long secsSince1900 = highWord << 16 | lowWord;
    Serial.print("Seconds since Jan 1 1900 = ");
    Serial.println(secsSince1900);
    // now convert NTP time into everyday time:
    Serial.print("Unix time = ");
    // Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
    const unsigned long seventyYears = 2208988800UL;
    // subtract seventy years:
    unsigned long epoch = secsSince1900 - seventyYears;
    // print Unix time:
    Serial.println(epoch);
    // print the hour, minute and second:
    Serial.print("The UTC time is ");       // UTC is the time at Greenwich Meridian (GMT)
    Serial.print((epoch  % 86400L) / 3600); // print the hour (86400 equals secs per day)
    Serial.print(':');
    if (((epoch % 3600) / 60) < 10) {
      // In the first 10 minutes of each hour, we'll want a leading '0'
      Serial.print('0');
    Serial.print((epoch  % 3600) / 60); // print the minute (3600 equals secs per minute)
    Serial.print(':');
    if ((epoch % 60) < 10) {
      // In the first 10 seconds of each minute, we'll want a leading '0'
      Serial.print('0');
    Serial.println(epoch % 60); // print the second
  // wait ten seconds before asking for the time again
  delay(10000);
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address) {
  //Serial.println("1");
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  //Serial.println("2");
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  //Serial.println("3");
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  //Serial.println("4");
  Udp.write(packetBuffer, NTP_PACKET_SIZE);
  //Serial.println("5");
  Udp.endPacket();
  //Serial.println("6");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Set the ip in an int array
int ip[4] = {129, 6, 15, 28};
IPAddress timeServer(ip); // time.nist.gov NTP server
KawasakiZx10r:
Set the ip in an int byte array
byte ip[4] = {129, 6, 15, 28};
I deserve that seeing as we know the IP ranges from 0 to 255 so a byte is best and half the size memory wise
in this way I do not solve the problem
Is NOT fixed!!!!I must be able to pass given by eeprom in my loop program
so you need to save the ip and read the ip to the EEPROM ? that what i assume your saying.
#include <EEPROM.h>
// write ip to EEPROM starting at block 0
for (int i = 0; i < 3; i++) {
    EEPROM.put(i, ip[i]);
// read ip from EEPROM starting at block 0
    ip[i] = EEPROM.read(i);
So i understood you issue after playing with the code and running it and i have rewritten it so that it works as you requested. It needs some adjustments to the localized arrays which should be global but are leave that to you its easy enough…
#include <SPI.h>
#include <WiFi.h>
#include <EEPROM.h>
byte savedPrior = 101;
WiFiUDP Udp;
  while (!Serial) {
  char ssid[] = "mynetwork";  //  your network SSID (name)  !!!!!!!! you may want to make these global so you can rewrite them ... but are leave that to you
  savedPrior = EEPROM.read(4); // write to EEPROM starting at block 4 === populates the EEPROM on the first ever run !!!!!!!!
  if (savedPrior != 101) {  // some EEPROMS are cleared with 0 and iv had others with 255 so i just picked 101 to be safe, true or false could be raised if it has been populated prior and is either 0 or greater ...
    EEPROM.put(4, 101);
  // read ip from EEPROM starting at block 1
  timeServer = ip;
    // don't continue:
    while (true);
    delay(10000);
  printWifiStatus();
    // print Unix time:
    Serial.print(':');
      Serial.print('0');
    Serial.print(':');
      Serial.print('0');
  delay(10000);
  Udp.endPacket();
  Serial.println(ip);
  Serial.print(rssi);
    for (int i = 1; i < 4; i++) {
@KawasakiZx10r - you need to retake “for loop 101”
Lol what’s wrong with it I’m starting to think your a … I haven’t seen a response from you that isn’t passive aggressive. Lol you could have said that I was starting the for loop at 1 and the array was not offset by -1, just simple swap savedPrior to block 4 from 0 and the the IP to block 0 or even just ip [i-1] that would be a helpful response… I had to start the loop at 1 as threr was data in block 0 but any who I resolved it without your help …
Arrays index from zero
(I don't do "passive")
