second section
if ((newCode[0] = 0) && (newCode[1] = 0)){
if (digitalRead(button1) == HIGH){ //if button1 is pressed
checkEntered1(1); //call checkEntered and pass it a 1
delay(250);//wait, needed for correct functioning, otherwise
//buttons are deemed to be pressed more than once
else if (digitalRead(button2) == HIGH){ //if button2 is pressed
checkEntered1(2); //call checkEntered1 and pass it a 2
delay(250); //wait
else if (digitalRead(button3) == HIGH){ //if button3 is pressed
checkEntered1(3); //call checkEntered1 and pass it a 3
delay(250); //wait
else if (digitalRead(button4) == HIGH){ //if button4 is pressed
checkEntered1(4); //call checkEntered1 and pass it a 4
delay(250); //wait
void checkEntered1(int button /* define the 1,2,3 or 4 as an integer called button */){ //check the first element of the entered[] array
if (entered[0] != 0){ //if it is not a zero, i.e. it has already been inputted
checkEntered2(button); //move on to checkEntered2, passing it "button"
else if(entered[0] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
entered[0] = button; //set the first element as the button that has been pressed
Serial.print("1: ");Serial.println(entered[0]); //for debugging
void checkEntered2(int button){ //check the second element of the entered[] array
if (entered[1] != 0){ //if it is not a zero, i.e. it has already been inputted
checkEntered3(button); //move on to checkEntered3, passing it "button"
else if(entered[1] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
entered[1] = button; //set the second element as the button that has been pressed
Serial.print("2: ");Serial.println(entered[1]); //for debugging
void checkEntered3(int button){ //check the third element of the entered[] array
if (entered[2] != 0){ //if it is not a zero, i.e. it has already been inputted
checkEntered4(button); //move on to checkEntered4, passing it "button"
else if (entered[2] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
entered[2] = button; //set the third element as the button that has been pressed
Serial.print("3: ");Serial.println(entered[2]); //for debugging
void checkEntered4(int button){ //check the fourth element of the entered[] array
if (entered[3] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
entered[3] = button; //set the final element as the button that has been pressed
Serial.print("4: ");Serial.println(entered[3]); //for debugging
delay(100); //allow time for processing
compareCode(); //call the compareCode function
void compareCode(){ //checks if the code entered is correct by comparing the code[] array with the entered[] array
for (int i = 0; i<4;i++){ //these three lines are for debugging
Serial.println(entered[i]);
if ((entered[0]==code[0]) && (entered[1]==code[1]) && (entered[2]==code[2]) && (entered[3]==code[3])){ //if all the elements of each array are equal
digitalWrite(redLed, LOW); // turn the red LED off
digitalWrite(greenLed, HIGH); //turn the green LED on
delay(2000);
digitalWrite(greenLed, LOW);
memset(entered, 0, 7);
//return to loop() (not really necessary)
else { //if you (or the intruder) get the code wrong
flash(); //call the flash function
for (int i = 0; i < 4; i++){ //this next loop is for debugging
entered[i] = 0;
void flash(){ // this is basically the blink example, look at that for an explantion of this, I wont insult your intelligence... oh wait, I already did that earlier when explaining the green LED flashing... sorry 'bout that
delay(250);
digitalWrite(redLed, HIGH);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
else if(newCode[0] != 0) {
delay(250); //wait
delay(250); //wait
delay(250); //wait
if ((entered[0]==newCode[0]) && (entered[1]==newCode[1]) && (entered[2]==newCode[2]) && (entered[3]==newCode[3])){ //if all the elements of each array are equal
delay(2000);
entered[i] = 0;
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
void setupLights(){ // a funky display run at reset
digitalWrite(redLed, HIGH); //turn both
digitalWrite(greenLed, HIGH); //LEDs on
delay(75); //wait
digitalWrite(redLed, LOW); //turn them
digitalWrite(greenLed, LOW); //off again
delay(75); //wait
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
asm volatile (" jmp 0");
