Hi, I am busy learning the arduino language and I am stuck on a piece of coding that do not fully undestand. The code is as follows:
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
int currentNumber = 0;
long codes[12] =
0xFD30CF, 0xFD08F7, // 0 ,1
0xFD8877, 0xFD48B7, // 2 ,3
0xFD28D7, 0xFDA857, // 4 ,5
0xFD6897, 0xFD18E7, // 6 ,7
0xFD9867, 0xFD58A7, // 8 ,9
0xFD20DF, 0xFD609F,
int number[10][8] =
{0, 0, 0, 1, 0, 0, 0, 1}, //0
{0, 1, 1, 1, 1, 1, 0, 1}, //1
{0, 0, 1, 0, 0, 0, 1, 1}, //2
{0, 0, 1, 0, 1, 0, 0, 1}, //3
{0, 1, 0, 0, 1, 1, 0, 1}, //4
{1, 0, 0, 0, 1, 0, 0, 1}, //5
{1, 0, 0, 0, 0, 0, 0, 1}, //6
{0, 0, 1, 1, 1, 1, 0, 1}, //7
{0, 0, 0, 0, 0, 0, 0, 1}, //8
{0, 0, 0, 0, 1, 1, 0, 1}, //9
void numberShow(int i) {
for (int pin = 2; pin <= 9; pin++) {
digitalWrite(pin, number[i][pin - 2]);
irrecv.enableIRIn();
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
if (irrecv.decode(&results)) {
for (int i = 0; i <= 11; i++) {
if (results.value == codes[i] && i <= 9) {
numberShow(i);
currentNumber = i;
Serial.println(i);
else if (results.value == codes[10] && currentNumber != 0) {
currentNumber--;
numberShow(currentNumber);
Serial.println(currentNumber);
Serial.println(results.value, HEX);
irrecv.resume();
I am refering spesifically to this bit:
numberShow(i);
currentNumber = i;
Serial.println(i);
----> I want to know what does irrecv.decode(&results)) mean and what does the & before results exactly do
Thank you
