Hi all,
I am trying to log on pachube my data. I am trying to follow the instructions proposed at
http://community.pachube.com/arduino/usb/pachuino
I must say now that this is my first contact with arduino.
I downloaded and installed the 3 libraries that are indicated in the instructions. I think (but not sure) that I installed them correctly.
My sketchbook location is d:\Docs\Arduino
The libraries were installed in d:\Docs\Arduino\libraries\
d:\Docs\Arduino\libraries\eeml
d:\Docs\Arduino\libraries\arduino
d:\Docs\Arduino\libraries\pachuino
Then I load the code proposed :
import processing.serial.;
import cc.arduino.;
import eeml.;
import pachuino.;
Pachuino p;
void setup(){
p = new Pachuino(this, Arduino.list()[0], 115200);
p.setPort(5230);
p.setKey("ENTER_PACHUBE_API_KEY_HERE");
// local sensors
p.addLocalSensor("analog", 0,"lightSensor");
p.addLocalSensor("analog", 1,"temperature");
p.addLocalSensor("digital", 2, "button");
p.addLocalSensor("digital", 5, "button2");
etc. etc. etc. etc. etc. etc.
but I get errors while verifying that code:
andreas_pachube:-1: error: variable or field 'onReceiveEEML' declared void
andreas_pachube:-1: error: 'DataIn' was not declared in this scope
andreas_pachube:-1: error: variable or field 'onReceiveRequest' declared void
andreas_pachube:-1: error: 'DataOut' was not declared in this scope
andreas_pachube:0: error: 'import' does not name a type
andreas_pachube:1: error: 'import' does not name a type
andreas_pachube:2: error: 'import' does not name a type
andreas_pachube:3: error: 'import' does not name a type
andreas_pachube:5: error: 'Pachuino' does not name a type
andreas_pachube.cpp: In function 'void setup()':
andreas_pachube:8: error: 'p' was not declared in this scope
andreas_pachube:8: error: expected type-specifier before 'Pachuino'
andreas_pachube:8: error: expected `;' before 'Pachuino'
andreas_pachube.cpp: In function 'void draw()':
andreas_pachube:27: error: 'p' was not declared in this scope
andreas_pachube.cpp: At global scope:
andreas_pachube:36: error: variable or field 'onReceiveEEML' declared void
andreas_pachube:36: error: 'DataIn' was not declared in this scope
andreas_pachube:39: error: variable or field 'onReceiveRequest' declared void
andreas_pachube:39: error: 'DataOut' was not declared in this scope
What am I doing wrong?
thank U
Andreas
