I have got a sketch that reads a button to switch between a dimmer mode and a PIR mode for an LED. The idea is to use a non blocking function for the PIR mode to be able to switch between modes at any time. I have got it kind of working, but somewhere is a mistake, since it doesn't matter whatever value i use for my function, the LED always turns on for the same amount of time. After googling and fiddling around for five hours now, could someone please tell me what's wrong there?
int switchPin = 2; // switch is connected to pin 2
int pir = 3; // pir sensor on pin 3
int potPin = A0; // brightness control
int statLed = 10; // mode indicator
int lightOut = 11; // LED strip will go here
int aVal; // variable for reading the pot
int val; // variable for reading the pin status
int val2; // variable for reading the delayed status
int buttonState; // variable to hold the button state
long previousMillis = 0;
long interval = 150000; //wait time for pir mode
int lightMode = 0; // dimmer mode or pir mode
pinMode(switchPin, INPUT_PULLUP);
pinMode(pir, INPUT);
pinMode(statLed, OUTPUT);
pinMode(lightOut, OUTPUT);
buttonState = digitalRead(switchPin); // read the initial state
void loop(){
val = digitalRead(switchPin); // checking and debouncing
delay(10);
val2 = digitalRead(switchPin);
if (val == val2) {
if (val != buttonState) {
if (val == LOW) {
if (lightMode == 0) {
lightMode = 1; // go to pir mode
else {
lightMode = 0; //go to dimmer mode
buttonState = val; // save the new state
if (lightMode == 0) { //dimmer
aVal = analogRead(potPin);
analogWrite(lightOut,map(aVal, 0, 1023, 2, 255));
digitalWrite(statLed,LOW);
else{ //pir
digitalWrite(statLed, HIGH);
// here is my problem
if(digitalRead(pir) == HIGH){
digitalWrite(lightOut, HIGH);
unsigned long currentMillis = millis();
if(currentMillis - previousMillis > interval){
previousMillis = currentMillis;
else{
digitalWrite(lightOut, LOW);
So I guess it doesn't and i started the whole thing out wrong?
No. You just didn't go far enough.
Look back at the blink without delay example. There is a time that something was last done. There is a current time. There is a comparison of now minus then to interval. If the comparison is true, there is an action block.
At least i found out that the time check doesn't seem to ever start, Serial.println(previousMillis); never happens. I still have got no idea why.
Here's the full version:
long interval = 90000; //wait time for pir mode
int ledState;
void loop(){
delay(10);
if (val == val2) {
if (val == LOW) {
else {
analogWrite(statLed,map(aVal,0,1023,200,2));
else{ //pir
else{
