Problem understanding the addressing of codes
Hey im new to arduino and programming The arduino is an awesome device I really need some help understanding these addresses i cant make heads or tales of it
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0xf0f0f0f0d2 0xf0f0f0f0e1
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0xf0f0f0f0d2
RX_PW_P0-6 = 0x08 0x08 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0f
DYNPD/FEATURE = 0x00 0x00
Data Rate = 1MBPS
Model = nRF24L01
CRC Length = 16 bits
PA Power = PA_HIGH
Its an extract from maniacbug's code RF24 Im trying to understand the 0xf0f0f0f0d2 for example but am unable to Please help me out Thank you so much
Which is what exactly? Link please.
That is simply a very long binary number in hexadecimal format. Look up what hex means. The 0x bit at the start means what follows is a hex number.
The lack of comers between multiple values on the same line make me think that this is not C code.
http://maniacbug.wordpress.com/2011/11/02/getting-started-rf24
https://github.com/maniacbug/RF24 Yep, not sure where the 'extract' is coming from - I don't see that list in the files here.
Even im not able to find it on github , its on the page i linked Ok in general how do i go about using the library and transmitting and receiving data? Any general help would be appreciated Thank you
Try starting with these then. http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
Thank you
akinich: Ok in general how do i go about using the library and transmitting and receiving data?
Look at the examples that come with ManiacBug's library - they demonstrate how to use it.
akinich: Its an extract from maniacbug's code RF24
No, it isn't. Have a look just above that sequence of lines on the page you linked to. It says
Upload the sketch, start the serial monitor, set the speed to 57600, and you should see this:
That means that it is the output of the sketch called "GettingStarted".
You need to download his library and place it into your Arduino\libraries folder, then include it. In the RF24 library folder, you will also find an examples directory, with the GettingStarted folder and in that, the GettingStarted.pde sketch.
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0 RX_ADDR_P0-1 = 0xf0f0f0f0d2 0xf0f0f0f0e1
no it's not, it's an extract from his web page showing what the RESULTS of some sketch look like. THIS IS NOT CODE! The way I read the tutorial, This is the way that things are supposed to look when you've done everything right and load up the ef24 "getting started" sketch.
That helps a lot Thank you
