Hi all,
I have got a WiFi shield and managed to make it work. Then I found out of a firmware update available and decided to do it.
The problem is I get an error message during the update and can't find a solution I've read many topics here and on other forums but can't find anyone with the same problem.
$ sudo sh ./ArduinoWifiShield_upgrade_mac.sh -f shield -a /Applications/Arduino.app/Contents/Resources/Java/
Arduino WiFi Shield upgrade
Disclaimer: to access to the USB devices correctly, the dfu-programmer needs to be used as root. Run this script as root.
****Upgrade WiFi Shield firmware****
Error opening the file.
Something went wrong with creating the memory image.
Done. Remove the J3 jumper and press the RESET button on the shield.
Thank you!
I had to fix the update script because it contained a wrong path
WIFI_FW_PATH="/hardware/arduino/firmwares/wifi-shield"
instead of
WIFI_FW_PATH="/hardware/arduino/firmwares/wifishield/binary"
And that solved another issue (some files were not found because of the wrong path).
But the error
stays, and now my wifi shield is not working I get this error when I run a sketch that was working previously
WiFi shield not present
I can't figure out where that error comes from.
Someone says the files might be corrupted and by downloading them again it could be fixed, but I have downloaded them from several sources and it didn't help
