Problem upload an file from sdcard to webserver
Hi my friends
I recorded a wave file with Arduino mega 2560 (microphone is connected to Arduino mega 2560) and now I want to upload the recorded wave file is stored in my sd card to a web server with ESP12-F module which connected to Arduino mega 2560 with serial (UART) port, So I can't remove Arduino mega 2560 because I used of it for recording voices;
Now my problem is in uploading recorded wave file from my sd card (which connected to Arduino mega 2560) to a web server.
The problem is when I sending a file with a less size of 32 kb to the webserver, it's working fine and the file has been uploaded but when the size of my file is bigger than 32 kb, I can't send this file.
I think the problem is from the size of the Serial buffer and I don't know my problem for buffer size or another problem!
additional explanation : ( I used WampServer app as webserver and this library (WifiEspAT.h) for communication with ESP12-F module )
this is Link's from WIFIESPAT.h library (GitHub - JAndrassy/WiFiEspAT: Arduino networking library. Standard Arduino WiFi networking API over ESP8266 or ESP32 AT commands.) and this is my sketch code
#include <WiFiEspAT.h>
#include <SD.h>
#include <SPI.h>
//#include <StreamLib.h>
File myFile;
String post_host = "192.168.1.103";
const int  post_port  = 80;
String  url = "/upload_file.php";
char server[] = "192.168.1.103";
// Emulate Serial1 on pins 6/7 if not present
#if defined(ARDUINO_ARCH_AVR) && !defined(HAVE_HWSERIAL1)
//#include <SoftwareSerial.h>
//SoftwareSerial Serial1(6, 7); // RX, TX
#define AT_BAUD_RATE 9600
#else
#define AT_BAUD_RATE 115200
#endif
//const char* server = "arduino.cc";
WiFiClient client;
//format bytes
String formatBytes(unsigned int bytes) {
  if (bytes < 1024) {
    return String(bytes) + "B";
  } else if (bytes < (1024 * 1024)) {
    return String(bytes / 1024.0) + "KB";
  } else if (bytes < (1024 * 1024 * 1024)) {
    return String(bytes / 1024.0 / 1024.0) + "MB";
  while (!Serial);
  Serial1.begin(AT_BAUD_RATE);
  WiFi.init(Serial1);
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  // waiting for connection to Wifi network set with the SetupWiFiConnection sketch
  Serial.println("Waiting for connection to WiFi");
    Serial.print('.');
  Serial.println("Connected to WiFi network.");
   //test connect to sd
  Serial.print("Initializing SD card...");
  if (!SD.begin(53))
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  //read file from SD
  //define file
  myFile = SD.open("data.wav", FILE_READ);
  String fileName = myFile.name();
  String fileSize = formatBytes(myFile.size());
  Serial.println("file exists");
  if (myFile)
    Serial.println("test file:ok");
    // print content length and host
    Serial.print("contentLength : ");
    Serial.println(fileSize);
    Serial.print("connecting to ");
    Serial.println(post_host);
    // We now create a URI for the request
    Serial.println("Connected to server");
    Serial.print("Requesting URL: ");
    Serial.println(url);
    // Make a HTTP request and add HTTP headers
    //String boundary = "CustomizBoundarye----";
    //change with your content type
    String contentType = "audio/x-wav";
    String portString = String(post_port);
    String hostString = String(post_host);
    String requestHead = "--RandomNerdTutorials\r\nContent-Disposition: form-data; name=\"data\"; filename=\"data.wav\"\r\nContent-Type: audio/x-wav\r\n\r\n";
    String tail = "\r\n--RandomNerdTutorials--\r\n";
    int contentLength =  requestHead.length() + myFile.size() + tail.length();
    client.connect(server, 80);
    client.println("POST " + url + " HTTP/1.1");
    client.println("Host: " + post_host);
    client.println("Content-Length: " + String(contentLength, DEC));
    client.println("Content-Type: multipart/form-data; boundary=RandomNerdTutorials");
    client.println();
    client.print(requestHead );
    // send myFile:
    //this method is for upload data very fast
    //and only work in ESP software version after 2.3.0
    //if your version is lower than please update
    //esp software to last version or use bellow comment code
    client.write(myFile);
    // create file buffer
    const int bufSize = 2048;
    byte clientBuf[bufSize];
    int clientCount = 0;
    while (myFile.available())
      clientBuf [clientCount] = myFile.read ();
      clientCount++;
      if (clientCount > (bufSize - 1))
        client.write((const uint8_t *)clientBuf, bufSize);
        clientCount = 0;
    if (clientCount > 0)
      client.write((const uint8_t *)clientBuf, clientCount);
    // send tail
    //      char charBuf3[tail.length() + 1];
    //      tail.toCharArray(charBuf3, tail.length() + 1);
    client.print(tail);
    //Serial.print(charBuf3);
    // if the file didn't open, print an error:
    Serial.println("error opening test.WAV");
    Serial.println("Post Failure");
  // Read all the lines of the reply from server and print them to Serial
  Serial.println("request sent");
  String responseHeaders = "";
  while (client.connected() ) {
    //      Serial.println("while client connected");
    String line = client.readStringUntil('\n');
    Serial.println(line);
    responseHeaders += line;
    if (line == "\r") {
      Serial.println("headers received");
  Serial.println("reply was:");
  Serial.println("==========");
  Serial.println("closing connection");
  //close file
  myFile.close();
and this is my php code :
<?PHP
    $path = "data/";
    $path = $path . basename( $_FILES['data']['name']);
    if(move_uploaded_file($_FILES['data']['tmp_name'], $path)) {
      echo "The file ".  basename( $_FILES['data']['name']).
      " has been uploaded";
    } else{
        echo "There was an error uploading the file, please try again!";
and this is Serial monitor response for wave file bigger and less than 32kb ( screenshot's PNG is attached )
(( and also I tested this code with ESP8266 NODE MCU and I can send a bigger file of about 1MB to the same webserver (WampServer) ))
If possible helping me :cry:
thanks....
No any one can help me?
You have declared your variable 'contentLength' to be of type 'int' which is 16 bits so can't hold values above 32k
Thanks Mr blh64 for your response
Can you guide me?
Can you tell me what variable to put instead of the int variable?
Or how to increase its volume, is there a way?
unsigned int can hold max. 65,535. If that's not enough you should use unsigned long: max. 4,294,967,295.
0xffffffff = (2^32)-1 = 4,294,967,295
CrossRoads:
Aiii, copy/paste error, sorry!
Thanks my friends
That's Work fine
But now i have a question
Do you think there is a way to reduce the time it takes to upload to the server? Because it now takes about thirteen seconds to send the file to the server
HI again my friends
not have any idea about that?!
