Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
Sketch uses 3676 bytes (11%) of program storage space. Maximum is 32256 bytes.
Global variables use 226 bytes (11%) of dynamic memory, leaving 1822 bytes for local variables. Maximum is 2048 bytes.
C:\Users\hp\OneDrive\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\hp\OneDrive\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\hp\AppData\Local\Temp\arduino_build_967770/ca_project.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\hp\OneDrive\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x3a
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
option enabled in File -> Preferences.
please help me . i bought this new arduino uno for a project and i am encountering this problem
Hi @fizix. I have some things you can try to fix the common causes of this error message:
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu in the Arduino IDE. Note that some boards have similar names, but are not interchangeable. Examples include "Arduino Uno" vs. "Arduino Uno WiFi" vs. "Arduino Uno WiFi Rev2", "Arduino Nano" vs. "Arduino Nano Every" vs. "Arduino Nano IoT" vs "Arduino Nano 33 BLE" vs. "Arduino Nano RP2040 Connect", "Arduino Duemilanove" vs. "Arduino Due".
Make sure you have selected the port of your Arduino board from the Tools > Port menu in the Arduino IDE.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don't know which port is your Arduino board, you can find it by doing this:
Unplug your Arduino board from the computer.
Select Tools > Port from the Arduino IDE menus.
Note the ports, if any, listed in the menu.
Close the Tools menu.
The ports list is only updated when the Tools menu is re-opened, so this step is essential.
Plug your Arduino board into the computer.
Select Tools > Port from the Arduino IDE menus. - The new port listed in the menu is the one for your Arduino board.
My experience has been that when you have a program that writes to the serial port regularly Serial.print(), and you have the Serial monitor window open, the programmer seems to often be unable to gain exclusive use of the serial port to start programming.
My solution when that happens is to close the serial monitor, then hit sketch>upload.
