Problem uploading code. ( stk500_getsync(), stk500_recv() )
I bought this Arduino Uno less than a month ago. It was working fine. Did some Projects too. But now I can't upload any code! Upoading gets stuck at the end and the following error message appears: "Arduino: 1.6.4 (Windows 7), Board: "Arduino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x7d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7d
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences. "
I have checked the proper board and serial port...... Also tried updating the driver which said " already up to date". But still I'm facing the problem.
Have a go at the loop-back test, it can be found at thr top of this sub-forum. Post your results here and i will try to help you.
