Problem Uploading Code to HC-06
Hi there,
I am having a problem uploading Arduino code from my PC to the HC-06 Bluetooth Module. Here is my setup: HC-06: GND- Ground of Arduino Uno Vcc - 3.3V RxD - Pin 11 of Arduino Uno TxD - Pin 10 of Arduino Uno
I am using Software Serial, with pin 10 as Rx and pin 11 as Tx.
I am able to send AT commands through a physical connection to the Uno. My PC is not a problem either - the bluetooth says I am connected to HC-06. My current setup is simple, with AT commands to change the name of the bluetooth module, the passcode and the baud rate (current setting is BAUD4, 9600).
Whenever I try to upload code from Arduino (using the output COM), it tries to upload and after a minute or so comes out with this error message:
avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd5 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd5 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd5 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd5 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd5 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd5 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd5 avrdude: stk500_recv(): programmer is not responding Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions. avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd5 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd5 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd5
Any help or suggestions would be much appreciated.
Thanks!
Here is the code I am trying to upload:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println(“Goodnight moon!”);
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
mySerial.println(“Hello, world?”);
void loop() { // run over and over
if (mySerial.available()) {
Serial.write(mySerial.read());
if (Serial.available()) {
mySerial.write(Serial.read());
Your post is far from coherent
sjalalov: I am having a problem uploading Arduino code from my PC to the HC-06 Bluetooth Module.
What exactly do you mean by uploading code from PC to HC-06? Do you mean you are trying to configure the HC-06 wirelessly? The HC-06 has two mutually excusive means of communication" AT mode by wires Communication mode by wireless
How are you using the HC-06? Is it bare, or is it on a breakout board? If the latter, you could be short of power.
Which is normal procedure
Which is incoherent. What code are you trying to upload from Arduino?
