Problem uploading code to uno with different firmware (Hoodloader 1.8)
Hey there!
I wanted to make a project where I use a Arduino as HID, but not wanted to buy a Micro/Zero/Leonardo. Flashing worked quite well (except some problems with Flip), but now, when I try to flash the code attached below (with Arduino Leonardo set as connected Board), I get the following output (Sorry if this is a bit too much, but I think it’s better if you can read it all):
Linking everything together…
“C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc” -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,–gc-sections -mmcu=atmega32u4 -o “C:\Users\Piepich\AppData\Local\Temp\arduino_build_202565/Mouse.ino.elf” “C:\Users\Piepich\AppData\Local\Temp\arduino_build_202565\sketch\Mouse.ino.cpp.o” “C:\Users\Piepich\AppData\Local\Temp\arduino_build_202565\libraries\HID\HID.cpp.o” “C:\Users\Piepich\AppData\Local\Temp\arduino_build_202565\libraries\Mouse\Mouse.cpp.o” “C:\Users\Piepich\AppData\Local\Temp\arduino_build_202565/core\core.a” “-LC:\Users\Piepich\AppData\Local\Temp\arduino_build_202565” -lm
“C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-objcopy” -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 “C:\Users\Piepich\AppData\Local\Temp\arduino_build_202565/Mouse.ino.elf” “C:\Users\Piepich\AppData\Local\Temp\arduino_build_202565/Mouse.ino.eep”
“C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-objcopy” -O ihex -R .eeprom “C:\Users\Piepich\AppData\Local\Temp\arduino_build_202565/Mouse.ino.elf” “C:\Users\Piepich\AppData\Local\Temp\arduino_build_202565/Mouse.ino.hex”
Multiple libraries were found for “HID.h”
Used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\HID
Not used: C:\Users\Piepich\Documents\Arduino\libraries\HID-master
Multiple libraries were found for “Mouse.h”
Used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Mouse
Using library HID at version 1.0 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\HID
Using library Mouse at version 1.0.1 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Mouse
“C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-size” -A “C:\Users\Piepich\AppData\Local\Temp\arduino_build_202565/Mouse.ino.elf”
Sketch uses 5650 bytes (19%) of program storage space. Maximum is 28672 bytes.
Global variables use 217 bytes (8%) of dynamic memory, leaving 2343 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port COM10
PORTS {COM3, COM4, COM10, } / {COM3, COM4, COM10, } => {}
Uploading using selected port: COM10
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM10 -b57600 -D -Uflash:w:C:\Users\Piepich\AppData\Local\Temp\arduino_build_202565/Mouse.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM10
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = “F”; type = @
Software Version = �.w; Hardware Version = �.
avrdude: error: buffered memory access not supported. Maybe it isn’t
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude done. Thank you.
Mouse.ino (2.74 KB)
