Problem uploading code.
When I verify my code it shows this error measage:
compilation terminated.
exit status 1 Error compiling for board Arduino/Genuino Uno.
How do I fix this problem? Thank you for your help.
You show us what else it says.
(deleted)
Is your problem anything like this?
This is the error measage and my code is below it. :
Arduino: 1.8.4 (Windows Vista), Board: “Arduino/Genuino Uno”
AppData\Local\Temp\Temp1_RFID_Kit_v2.0_for_Arduino.zip\RFID Kit v2.0 for Arduino\Lesson22 Real-time Clock Module\code\clock\clock.ino:11:20: fatal error: DS1302.h: No such file or directory
#include <DS1302.h>
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
And this is my code:
  • name:Real-time Clock Module
  • function:you can see the current date and time displayed on the I2C LCD1602.
    //Email:support@sunfounder.com
    //Website:www.sunfounder.com
//include the libraries
#include <stdio.h>
#include <string.h>
#include <DS1302.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
uint8_t RST_PIN = 5; //RST pin attach to
uint8_t SDA_PIN = 6; //IO pin attach to
uint8_t SCL_PIN = 7; //clk Pin attach to
/* Create buffers */
char buf[50];
char day[10];
String comdata = “”;
int numdata[7] ={ 0}, j = 0, mark = 0;
/* Create a DS1302 object */
DS1302 rtc(RST_PIN, SDA_PIN, SCL_PIN);//create a variable type of DS1302
void print_time()
/* Get the current time and date from the chip /
Time t = rtc.time();
Name the day of the week /
memset(day, 0, sizeof(day));
switch (t.day)
case 1:
strcpy(day, “Sun”);
case 2:
strcpy(day, “Mon”);
case 3:
strcpy(day, “Tue”);
case 4:
strcpy(day, “Wed”);
case 5:
strcpy(day, “Thu”);
case 6:
strcpy(day, “Fri”);
case 7:
strcpy(day, “Sat”);
Format the time and date and insert into the temporary buffer /
snprintf(buf, sizeof(buf), “%s %04d-%02d-%02d %02d:%02d:%02d”, day, t.yr, t.mon, t.date, t.hr, t.min, t.sec);
Print the formatted string to serial so we can see the time */
Serial.println(buf);
lcd.setCursor(2,0);
lcd.print(t.yr);
lcd.print("-");
lcd.print(t.mon/10);
lcd.print(t.mon%10);
lcd.print("-");
lcd.print(t.date/10);
lcd.print(t.date%10);
lcd.print(" “);
lcd.print(day);
lcd.setCursor(4,1);
lcd.print(t.hr);
lcd.print(”:");
lcd.print(t.min/10);
lcd.print(t.min%10);
lcd.print(":");
lcd.print(t.sec/10);
lcd.print(t.sec%10);
rtc.write_protect(false);
rtc.halt(false);
lcd.init(); //initialize the lcd
lcd.backlight(); //open the backlight
//Time t(2015, 6, 15, 17, 59, 50, 2);//initialize the time
/* Set the time and date on the chip */
//rtc.time(t);
/add the data to comdata when the serial has data /
while (Serial.available() > 0)
comdata += char(Serial.read());
delay(2);
mark = 1;
Use a comma to separate the strings of comdata,
and then convert the results into numbers to be saved in the array numdata[] /
if(mark == 1)
Serial.print("You inputed : ");
Serial.println(comdata);
for(int i = 0; i < comdata.length() ; i++)
if(comdata == ‘,’ || comdata == 0x10 || comdata == 0x13)
_ {
* j++;
else*
numdata[j] = numdata[j] * 10 + (comdata - ‘0’);
/ The converted numdata add up to the time format, then write to DS1302*/
* Time t(numdata[0], numdata[1], numdata[2], numdata[3], numdata[4], numdata[5], numdata[6]);
rtc.time(t);
mark = 0;
j=0;
/ clear comdata ,in order to wait for the next input /
comdata = String("");
/ clear numdata /
for(int i = 0; i < 7 ; i++) numdata=0;
/ print the current time /_
print_time();
_ delay(1000);
}*_
So, the answer to my question is "yes".
Please do not cross-post, cross-posting wastes time.
Please direct answers to the linked topic.
And code tags. We love code tags. Thread locked.
