Problem Uploading Sketch on my Arduino / Genuino Zero
Hi! I am using a Mac Book Air (Intel Core i5) (OS X El Capitan Version 10.11.3). I am trying to upload a basic sketch to an Arduino/Genuino Zero and i get the following error message.
Arduino: 1.6.5 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
Also i notice that the board name appears as Arduino/Genuino Uno but not Arduino/Genuino Zero.
You might have realised that i am rather a beginner:) Would appreciate a lot if anyone has suggestions.
Best!
Can you select Tools > Board > Arduino/Genuino Zero(Programming Port)?
Yes i did actually.
I tried again, exactly in the same way. This time i got a different Error Code:
Sketch uses 8,156 bytes (3%) of program storage space. Maximum is 262,144 bytes.
Open On-Chip Debugger 0.9.0-gd4b7679 (2015-06-10-19:16)
Licensed under GNU GPL v2
For bug reports, read
    http://openocd.org/doc/doxygen/bugs.html
debug_level: 0
adapter speed: 500 kHz
adapter_nsrst_delay: 100
cortex_m reset_config sysresetreq
target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x61000000 pc: 0x00000858 msp: 0x200023a0
** Programming Started **
auto erase enabled
wrote 24576 bytes from file /var/folders/97/pf6ry3cn6b51vc9yjgq6gj5m0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/Blink.ino.bin in 3.370556s (7.120 KiB/s)
** Programming Finished **
** Verify Started **
verified 8308 bytes in 0.713223s (11.376 KiB/s)
** Verified OK **
** Resetting Target **
shutdown command invoked
