Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions
My new Arduino always gives me an error
Have you read the pinned posts at the top of the forum you've posted in?
How about telling us a bit more about your setup.
What board are you having problems with. What OS are you using, etc....
I use Manjaro Linux with an Arduino Uno. I press upload and my error comes.
Did you select the correct port?
Are you as member of the dialout group?
Is your board correctly recognised? lsusb and dmesg can give insight in that.
You can enable verbose output during upload (please disable verbose output during compilation) in file -> preferences in the IDE. After the error, click the copy error messages button at the right in the orange bar and next paste here in a reply.
:arrow_up: lsusb
Arduino: 1.8.16 (Linux), Board: "Arduino Uno"
Sketch uses 3796 bytes (11%) of program storage space. Maximum is 32256 bytes.
Global variables use 255 bytes (12%) of dynamic memory, leaving 1793 bytes for local variables. Maximum is 2048 bytes.
/home/linux/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/linux/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b115200 -D -Uflash:w:/tmp/arduino_build_986005/sketch_oct25a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "/home/linux/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
     User configuration file is "/home/linux/.avrduderc"
     User configuration file does not exist or is not a regular file, skipping
     Using Port                    : /dev/ttyUSB0
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "/dev/ttyUSB0": Permission denied
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
avrdude done. Thank you.
option enabled in File -> Preferences.
Emphasis added :wink: Are you a member of the dialout group? If not, add yourself. After doing so you have to logout and login for the changes to take effect.
Can you tell me how to do that, please?
Thanks!
https://www.arduino.cc/en/guide/linux#toc6.
It is not working
From your error message, it's not /dev/ttyACM but /dev/ttyUSB0
Finally! I did it
But same error still comes
Which error? Please post it here.
Sorry, it's fixed now.
Thanks a lot for helping!
What did you do to fix it?
Run these commands.:
sudo usermod -a -G dialout $USER
sudo chmod a+rw /dev/ttyUSB0
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
Sketch uses 3168 bytes (9%) of program storage space. Maximum is 32256 bytes.
Global variables use 208 bytes (10%) of dynamic memory, leaving 1840 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2e
@somesh0710
Correct port selected?
Correct board selected?
Which board; some boards 'share' the RX and TX pins with the usb-to-ttl converter; connecting something to those pins can interfere with the upload.
A post was split to a new topic: An error occurred while uploading the sketch2
A post was split to a new topic: Ayuda con "avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x04"
merhabalar benimde aynı sorunu yasıyorum
prblem uploading to board see https://support.arduino.cc/hc/en-us/sections/360003198300for suggestions
bu problemi çözemedim yardım edermisiniz windows10 arduino 1.8 kullanıyorum kart arduino uno
