Problem uploading to board.
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
Build options changed, rebuilding all Sketch uses 2550 bytes (7%) of program storage space. Maximum is 32256 bytes. Global variables use 218 bytes (10%) of dynamic memory, leaving 1830 bytes for local variables. Maximum is 2048 bytes. avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc8 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc8 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc8 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc8 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc8 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc8 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc8 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc8 avrdude: stk500_recv(): programmer is not responding Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions. avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc8 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc8
This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
So, did you try the troubleshooting suggestions? If so, what happened (see the forum support section)?
i am not be able to connect my arduino lilypad to computer via ftdi
If you have a lilypad, why are you uploading to an Uno? Go to the Tools menu in the IDE and under Boards choose the lilypad board that you have.
@adnanrk has a Uno, maybe.
@xaffi entered the fray with a Lilypad. :confused:
So right. Lapse of attention on my part.
