Problem uploading to board1
Arduino: 1.8.14 Hourly Build 2020/08/17 01:33 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 2090 bytes (6%) of program storage space. Maximum is 30720 bytes.
Global variables use 206 bytes (10%) of dynamic memory, leaving 1842 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Commander\Desktop\CODING\arduino\hardware\tools\avr/bin/avrdude -CC:\Users\Commander\Desktop\CODING\arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\COMMAN~1\AppData\Local\Temp\arduino_build_354445/code_lock.ino.hex:i
avrdude: Version 6.3-20190619
     Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\Commander\Desktop\CODING\arduino\hardware\tools\avr/etc/avrdude.conf"
     Using Port                    : COM1
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
option enabled in File -> Preferences.
const int BTN_1 = 5;
const int BTN_2 = 6;
const int BTN_3 = 7;
const int BTN_4 = 8;
const int BTN_5 = 9;
const int BTN_6 = 10;
const int BTN_7 = 11;
const int BTN_8 = 12;
const int BTN_9 = 13;
int buttonState = 0;
const int BUTTONS[] = {BTN_1, BTN_2, BTN_3, BTN_4, BTN_5, BTN_6, BTN_7, BTN_8, BTN_9};
  for (int i = 0; i <= 9; i++){
      pinMode(BUTTONS[i], INPUT);
  check_BTN();
void check_BTN(){
      buttonState = digitalRead(BUTTONS[i]);
      switch (buttonState){
        case HIGH:
          Serial.println(BUTTONS[i]);
        case LOW:
        default:
          continue;
@thepixelexpertyt
TOPIC SPLIT
PLEASE DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Make sure you have selected the port of your Arduino board from the Arduino IDE's Tools > Port menu:
  1. Unplug your Arduino board from the computer.
  2. Select Tools > Port from the Arduino IDE's menus.
  3. Note the ports, if any, listed in the menu.
  4. Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  5. Plug your Arduino board into the computer.
  6. Select Tools > Port from the Arduino IDE's menus. - The new port listed in the menu is your Arduino board.
Are you sure you selected the right port? COM1 is usually a built-in serial port. Does any other port show up in the Tools->Port menu? If not, you may need to install a driver if your "Nano" is a clone that doesn't use an FTDI-brand serial chip.
Yes it is on port 1 , if it is a clone where would I get the driver?
That sounds strange. What does device manager show?
nothing showed than i tried to connect it to my usb hub (on port COM5) and i got this error : Arduino: 1.8.14 Hourly Build 2020/08/17 01:33 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 2106 bytes (6%) of program storage space. Maximum is 30720 bytes.
Global variables use 208 bytes (10%) of dynamic memory, leaving 1840 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Commander\Desktop\CODING\arduino\hardware\tools\avr/bin/avrdude -CC:\Users\Commander\Desktop\CODING\arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\COMMAN~1\AppData\Local\Temp\arduino_build_769913/code_lock.ino.hex:i
Using Port : COM5
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
An error occurred while uploading the sketch
It is using the same code with just using a different port, also when i go in device manager it shows up. thats why i think it is a clone and i need to get a different driver, so where can i get one lol
How do you know it is COM5?
If it shows up in Device Manager, then it's probably not a bad UART chip on the Arduino.
Try not using the hub.
Try using a different PC.
Try using a different Arduino.
Try using a different USB cable.
i did all of those and even installed the correct drivers on my laptop for it (my laptop is the second pc that i tried) and i keep getting that error
this is the error :
Arduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 796 bytes (2%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
this is the error with the verbose on :
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\kmjed\OneDrive\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10815 -build-path C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056 -warnings=none -build-cache C:\Users\kmjed\AppData\Local\Temp\arduino_cache_642206 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\kmjed\OneDrive\Documents\Arduino\sketch_aug06a\sketch_aug06a.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\kmjed\OneDrive\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10815 -build-path C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056 -warnings=none -build-cache C:\Users\kmjed\AppData\Local\Temp\arduino_cache_642206 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\kmjed\OneDrive\Documents\Arduino\sketch_aug06a\sketch_aug06a.ino
Using board 'nano' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056\sketch\sketch_aug06a.ino.cpp" -o nul
Generating function prototypes...
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056\sketch\sketch_aug06a.ino.cpp" -o "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056\sketch\sketch_aug06a.ino.cpp" -o "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056\sketch\sketch_aug06a.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\kmjed\AppData\Local\Temp\arduino_cache_642206\core\core_arduino_avr_nano_cpu_atmega328_94baf922c9d38d8316eaa2affe0e6dcb.a
Linking everything together...
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056/sketch_aug06a.ino.elf" "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056\sketch\sketch_aug06a.ino.cpp.o" "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056/..\arduino_cache_642206\core\core_arduino_avr_nano_cpu_atmega328_94baf922c9d38d8316eaa2affe0e6dcb.a" "-LC:\Users\kmjed\AppData\Local\Temp\arduino_build_180056" -lm
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056/sketch_aug06a.ino.elf" "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056/sketch_aug06a.ino.eep"
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056/sketch_aug06a.ino.elf" "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056/sketch_aug06a.ino.hex"
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-size" -A "C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056/sketch_aug06a.ino.elf"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\kmjed\AppData\Local\Temp\arduino_build_180056/sketch_aug06a.ino.hex:i
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
"Try not using the hub.
Try using a different USB cable."
Really?
I'm still sure you aren't using the correct com port. In your tools/port menu, try them all- starting with the last one. On EVERY PC I have, COM1 is internal to the PC. You can't plug anything into COM1.
yea, i have done all the ports on every pc (COM5 is the only one that shows up on my laptop and on my pc any COM that i plug the Arduino into)
Your error messages are saying that the selected com port is not communicating with the board. Since you are getting the same error on two PCs, then I would suspect the board. My next step would be to grab another Arduino or ESP board and flash the "blink" sample sketch from the IDE.
I wonder if it is the same issue as discussed here. The solution in that case was to uninstall the current USB-Serial driver and let the OS re-install it.
I don’t think that will work because even with installing the proper drivers on 2 different PCs it dosent work
In the previous case, I think the subtle difference was that the OS installed the drivers rather than the user.
Select Tools > Processor > ATmega328P (Old Bootloader) from the Arduino IDE's menus and then try uploading again.
it worked thanks, i think it was the combo of uninstalling the driver and using the old bootloader
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
