I have an Arduino Nano CH340, device manager recognizes it as such, so the drivers must be fine (right?). I'm sure I'm using the correct COM port (tried switching ports, nothing changed), nothing plugged into pin 0 or any other, the board is working fine, or at least is was 30 min ago, I literally just uploaded a sketch, it worked, I went to the bathroom, and when I came back it no longer uploaded.
I've had the same problem happen in the past, and switching to the old bootloader fixed it, but now it doesn't anymore.
Getting this error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x75
I've tried using the old bootloader, the new one, going back and forth on a few AVR board versions (currently 1.8.6), but nothing works. It did stop working about an hour after updating the IDE to version 2.2.1, could that be it?
The board is still running the last sketch I was able to upload, exactly the same for my 2 other CH340 Nanos.
