Problem uploading to Mega.
Hi, I have had this problem before then it seemed to clear, but I don't understand why.
I am using Mega board with CH340C Chip and a prototype shield. I am using 1.6.8 and have never understood which of the "programmer" tabs in tools I should be using. The program when installed on the bench works well, however now that it is the box I want to allow the day date to upgrade to my PC information. It compiles OK, but when I come to upload the uploading green line gets to the end and goes no further.
I then get the timed out error.
I have spent the morning on the various web sites but can't find a real answer that works.
Any help gratefully received, but please make it for a simple mind as I'm mid 70's
PyrusBoy:
The only time that matters is if you are doing a Tools > Burn Bootloader or Sketch > Upload Using Programmer. If you're doing a standard Upload then it makes absolutely no difference which programmer you have selected.
PyrusBoy:
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
Hello Shannon Member,
Many thanks for coming back to me.
Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino: In function 'int Message(int, int)':
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:367:1: warning: no return statement in function returning non-void [-Wreturn-type]
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino: At global scope:
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:421:20: warning: unused parameter 'OnOff' [-Wunused-parameter]
 void TurnMotor(int OnOff) {
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino: In function 'void TurnPump(int, int)':
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:439:17: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
   if (OnOff = On) {
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino: In function 'void DisplayTimes()':
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:540:9: warning: unused variable 'aux' [-Wunused-variable]
   int   aux;
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino: In function 'void ProcessChooseMash()':
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:765:16: warning: statement is a reference, not call, to function 'CleanDisplay2' [-Waddress]
   CleanDisplay2;
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:765:16: warning: statement has no effect [-Wunused-value]
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino: In function 'void ProcessChooseBoil()':
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:903:16: warning: statement is a reference, not call, to function 'CleanDisplay2' [-Waddress]
   CleanDisplay2;
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:903:16: warning: statement has no effect [-Wunused-value]
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino: In function 'void ProcessMash()':
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:1260:58: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
            && (((millis() / 1000) - TimeMashStepStarted) > StepProfile.Time[CurrentMashStep - 1] * 60)
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:1259:6: warning: suggest explicit braces to avoid ambiguous 'else' [-Wparentheses]
   if (     (WaitForOkButton == false)
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino: In function 'void ProcessBoil()':
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:1395:97: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
           (((millis() / 1000) - CurrentBoilStepStarted) + BoilProfile.TimeOfHop[HopNumber] * 60 >= (BoilProfile.MinutesTotal * 60) )) { // and it's time to add a hop/whirflock (BoilMinutesTotal - TimeElapsed) <= time to add Hop
C:\Arduino Brew Sketches\Large_Brew_Panel_complete\Large_Brew_Panel_complete.ino:1410:57: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
           (((millis() / 1000) - CurrentBoilStepStarted) > ((BoilProfile.MinutesTotal * 60)))) { // Time of Boil (boilOn) is greater than Total Boil time for the profile + delays in the hop additions
Sketch uses 25,842 bytes (10%) of program storage space. Maximum is 253,952 bytes.
Global variables use 2,088 bytes (25%) of dynamic memory, leaving 6,104 bytes for local variables. Maximum is 8,192 bytes.
C:\Users\Roger Ashley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Roger Ashley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM4 -b115200 -D -Uflash:w:C:\Users\ROGERA~1\AppData\Local\Temp\build7f09e53decd7765c6bd8967f34ea209d.tmp/Large_Brew_Panel_complete.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Roger Ashley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\\.\COM4": Access is denied.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
(deleted)
